Quaife LSD
Quaife LSD
For those who are tired of the little orange triangle on their Mercedes AMG lighting up like a christmas tree everytime throttle is applied and are interested in a limited slip differential, I have negotiated a price with Vivid Racing for the Quaife units. Normally they retail for $1795, and Vivid is willing to sell them to us for $1580 "out the door" (i.e. free domestic shipping).
So if you're interested call Michael at Vivid Racing (480 966-3040 ext 226) to place your order.
In an effort to avoid writing a long soporific response (which is probably not technically accurate anyhow), I suggest that you visit www.quaifeamerica.com and click on ATB differentials to get an understanding on how the Quaife unit works versus other LSDs.
AMG offers an LSD through their Manufaktur program for our cars. However, their LSD is (i) difficult to obtain in the US, (ii) at least twice as expensive as the Quaife unit, and (iii) does not provide nearly as much lock up as the Kleeman or the Quaife unit.
2017 S63 Coupe Iridium Silver
It's called fast food research, also known as McResearch. All information is predigested, easy to swallow but in the end very unsatisfying, so they come back for more.
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
2015 S212
Originally Posted by Rafal
That is a good answer. A lot of guys on these forums post a one line question to a complicated answer and expect an instant, single line answer, preferably monosyllabic.
It's called fast food research, also known as McResearch. All information is predigested, easy to swallow but in the end very unsatisfying, so they come back for more.![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
mmm, tasty. Actually, not very filling, though. Hmmm.....
20+ to list......
Vivid Racing? A name way too familiar for me. I have not only ordered from them, but heard lots of stories about them. Mostly negative in terms of customer services and shipping. So if I were you, I would look somewhere else.
20+ to list......
Really? What have your experiences with them been. They seem to run a legit operation.
2003 E55
[QUOTE=2QUIK4U]In an effort to avoid writing a long soporific response (which is probably not technically accurate anyhow), I suggest that you visit www.quaifeamerica.com and click on ATB differentials to get an understanding on how the Quaife unit works versus other LSDs.
Interesting website - thanks.
Question - if you remove the wheel spin, wont the drive train peak load increase? Could this create a longterm durablity problem?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
2015 S212
[quote=OzE55]
In theory, absolutely. Most mods that strengthen one component can have an adverse effect on others. In this case, no doubt the rear end will wiggle more as the rear bushing give under more power. That can also be worked on, which will send that power up the chain (i.e. tranny, etc.)
Having said that, keep in mind that we hare not taking a design that handles little torque to one that is massive. our cars have plenty of it to start with and this tranny is also pretty strong.
In the past, I have had great results with just changing out as many bushings as i can. i prefer the nice polyU aftermarket or custom ones. They make a world of difference, but can be very expensive to install.
Question - if you remove the wheel spin, wont the drive train peak load increase? Could this create a longterm durablity problem?![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
I had a slight "wiggle" problem after the Quaife, which was worsened with Drag Radials on the car. It felt like the rear wheels were going toe-in under heavy load. Put the car on the lift and, sure enough, the toe links are rediculously flimsy on these cars. Renntech makes a set for these cars, but they wanted too much so we made our own. Works badass and the rear end feels way more stable under heavy load.
I have no idea what the C55's rear suspension architecture looks like. The best answer I can give is "probably", but I can't tell you exactly how or where. The problem may turn up as toe in instead of toe out or some other geometry change. Best thing to do is get the car in the air and just look around under there.
2015 S212
Would the C55 also be susceptible to this problem?
I know many on this board blame the wiggle on 295s (claiming they rub the body), but I believe it to be the bushings.
RENNtechs are expensive, but VERY nice. I will get them along with the Quaffe.
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
2015 S212
Originally Posted by GTA23109a
The ones HP Autowerks in Santa Barbara built me are pretty badass. I'll try to take some pics this weekend (it's HOT right now
) but they're way cheaper than the renntech ones.
2007 S65, 2005 Nissan Armada
Yes they would, BUT you have less power so the problem will be less prominant.
Hey Jangy you might be right that the bushings also have something to do with the wiggle, but for me at least the rears rubbing is not a "claim" as you say it is fact.
2015 S212
I apologize about that statement. I know that 295s are hard to fit and rub under most conditions. In fact, I think i am the only one that claims to have finally overcome this issue, and by using CLS rims no less. I do not mean to belittle ANYONE'S experiences, so I will clarify. What I meant to say is that I do not believe that the rubbing is what is causing the wagging. Keep in mind that not all "wagglers" rub. But, ALL wagglers have increased traction somehow (by increased tire size or better compund). There may be a correlation effect, I just do not believe it is causative. For there to be enough power loss at the tire level to cause such waggling, I would really expect the entire fender to be deformed. There is a HUGE amount of power being put down under hard acceleration and a slight rub just won't act as a braking device without doing some damage.
If for some reason you are coming to Miami PM me and I'll put the 20's back on so you can see for yourself. Maybe one day we will figure this out for sure.
2015 S212
If for some reason you are coming to Miami PM me and I'll put the 20's back on so you can see for yourself. Maybe one day we will figure this out for sure. ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Again, I never meant to belittle yours or anyone elses issues or experiences with their rides as I would also hate to have something odd about my car. My aim has only been to fit 295s on the rear and 275s on the front. I really wanted this more for handling than anything, as the PS2s (275/35) do work great in the rear.
Keep in on the road and keep letting me know when I stick my foot in my mouth
