The 63 engine performance.
You need to stand behind something bigger than that, if you think you can hide from reality.
The only flaw I see with the 7 speed transmission is the odd spacing of ratios from 4th onwards. Again, MB's limitations have stopped AMG from really flexing its muscles. I mean, they made the engine from the ground-up, would it have hurt to ask Ricardo to make a custom 7 speed for this masterpiece V8? They did it for the Veyron. Also, in that Chrysler supercar contraption (ME412?) the powerplant was a quad-turbo 65 motor with (guess what?) a custom Ricardo transmission.
Maybe I'm asking too much but they way I see it, if my bank can move its customer service to India, then AMG can surely outsource the transmissions!
It’s not the number of cylinders it’s the displacement (and compression ratio)that makes torque in a normally aspirated engine.
There is no replacement for displacement. Let me correct myself: there is one: Cubic dollars. But for everything else, add the cubes.
Displacement rules the land of torque, because in an internal combustion the engine produces power by burning fuel and air. The key to gaining more power is simply to add more air and fuel. The key limitation is the ability of the engine to intake air. In a normally aspirated engine air is drawn in the engine by the vacuum created during the intake stroke. The larger the engine displacement, the more vacuum produced. It's that simple. More air allows more fuel, and more power follows. M5 has a very short stroke (75 mm) made for High revs vs. the 63 long stroke (94 mm) for more low end grunt.
Torque is the static measurement of how much work an engine does, while power is a measure of how fast the work is being done. Since horsepower is calculated from torque, what we are all seeking is the greatest-possible torque value over the broadest-possible rpm range. Horsepower will follow suit, and it will fall in the engine speed range dictated by the many factors that affect the torque curve.
Increased displacement is the easiest way to achieve increased torque. Very large cylinders and a long stroke offer the greatest cylinder volume and overall piston area for the fuel charge to push against the crankshaft.
Again, the ability to flow air in and out of the engine is the key for power. You can improve breathing by smoothing airflow in and out of the engine, and by increasing valve area. The second way is to simulate a larger displacement through pushing smaller cycles through the engine (M5), in essence by out-revving the other engine but losing torque. That may not be enough to overcome any displacement disadvantages. The M5 motor does a great job producing power quickly with the thanks being given to its lightweight internal parts. This is one reason the M5 can accelerate its mass quickly with out producing gobs of torque (not to mention it’s gearing).
The bigger motor enjoys one big advantage; torque. Big motors (e63) produce lots of it, and produce torque practically everywhere. Smaller motors can produce torque (M5), but in a much narrower rev band. And generally higher up in the rev band, which makes the torque harder to use.
My fingers hurt. Gotta go to the track now. Cheers!
If you have two engines of the same size but with a different number of cylinders, and they have similar tuning and volumetric efficiencies, they will produce similar power.
Let's look at the M5 and E63 engines. The M5 uses a 5.0 lt V-10. The E63 uses a 6.2 lt V-8. The peak torque of the M5 is 383 lb-ft and the peak torque of the E63 is 465 lb-ft. That's about 38 and 58 lb-ft per cylinder, respectively. If you make the M5 engine the same size as the E63 engine, it would require 12.5 cylinders. Multiply those 12.5 cylinders by the 38 lb-ft/cylinder M5 torque value and you get 475 lb-ft, which is about a 2% difference from the E63. This 2% difference can be attributed to the tuning/volumetric efficiency components, which appear to be similar between the two engines.
BMW chose to use a V-10 because of the reduced reciprocating weight of the smaller piston/rod assemblies. This reduced weight allows higher RPMs, which translates into more HP, assuming the engine can handle the increased airflow. As a consequence, their 5.0 lt V-10 puts out similar HP figures to AMG's 6.2 lt V-8.
You are wise to disengage from the other poster. He has demonstrated little more than a superficial knowledge of the relavent topics in his posts, and when he can't substantiate his claims, he becomes belligerent and abusive.
Choson1, what rims are they on your 645?! nice!
it's funny cuz i've been a bimmer faithful for the longest time, but as i get older, i'm becoming more attracted to AMG's...
i have no doubt there are many people here that have plenty of knowledge and i'm always willing to learn a few things. btw, thanks for the heads up on the belligerent and abusive part.
Glad you've been warned, newb. Now we can get into it. hehe!!
I agree on displacement, but what if both are the same?
For example, comparing a 6.0L V8 to a 6.0 V12.
I was always under the assumption that the more cylinders would mean a higher TOTAL torque, even though each cylinder would make less.
You are a cool cat, so I am ready to learn....
I can see your point in a lap type of race, where overall time is the concern.
So, basically, you are saying that more cylinders tend to narrow the powerband, even if they do have a good peak? If so, I am getting that. If not, give me time and I'll come around.
Assuming we are on the same page on that, could I not argue that the more cylinders can also peak sooner? That may be a bad thing for lap racers, since more RPM is more power and you want to be in a good band at all times; but it would be a good thing for a drag racer as it gives a nice launch. That is more what I was thinking. Make sense?
Something along the lines of more power strokes in a given period of time should result in more torque than a similar engine with fewer cylinders.
What's up dude? You were MIA for awhile heh? Still up for a few runs?
http://web.mac.com/markblosil/iWeb/S...%20M5%202.html
It is all basic physics and I just don't see what will change with arguing, so I let it go.
S2 means the Stage 2 package.
Figure 470hp and 419lb-ft torque as per Dinan's website.
It's a mean machine. There used to be one in my neighborhood; black on black.
Impressive video? Heck no.
Keep in mind our strength is in the torque, so finding another car with 470hp and saying it compares to an E55K is just off.
I passed on an 2006 E55 in favor of the 63, which I will order once the car proves itself in the market. Can't wait.
The E63 may or may not perform in a class with the NEW M5, but it will definitely drive like a Benz.
