Help on rims please?
Will these fit my E55 ??
has 255/35/19
8.5x19EH2
ET30
A2114001202
A1714000302
has 285/30/19
9.5Jx19xEH2
ET31
A2114001402
A1714000402
See here looks like a decent deal including tyres..?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=220010123200
has 255/35/19
8.5x19EH2
ET30
A2114001202
A1714000302
has 285/30/19
9.5Jx19xEH2
ET31
A2114001402
A1714000402
Need to know if the rears with 9.5" width (31 offset) will rub with 285 shoes ... I know the 10" width (33 offset) rubs with 285 rubber but will the 9.5"?
Fronts should be fine right ?
Yes & brand new ... dips though !!!!
Pity about the rubber I would have wanted Yoko's and 275's.. mbe some tire shop will swap 'em out...
E55 AMG
I have the SL65 wheels on my car which have the same specs, if your car is stock height you will no problem, however, if you have lowered your car, the rear will rub for sure as I had the same problem.
There is a fix for this, I swapped the offsets from the back to the front and so on!...by undoing all the the wheels and swapping the middle sections around, I found this eliminated rubbing and has given the car a more aggresive look.
if you are unsure, you are welcome to take a look at my car.
