RE : TPMS sensor on rim...
Old Jul 25, 2006 | 12:30 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
If I swap out my rims - do the tyres have to come off to fit the TPMS sensor on the new rims , or can the refit of the TPMS be done without removing the tyre?
Old Jul 25, 2006 | 12:34 PM
sprins's Avatar
G55, SLS, smart eq
AFAIK tire removal is necessary.
Old Jul 25, 2006 | 02:41 PM
pas's Avatar
pas
2007 S65, 2005 Nissan Armada
The TPMS sensors will not fit every type of rim. The tire rack sells them though I believe the manufacturer is Beru. They might be able to tell you if the sensors will fit the wheels you are considering.
Tires have to be removed or at the very least deflated and the bead broken to access and remove the sensors.
