12.6 sec @ 181km/h
12.6 sec @ 181km/h
ran me personal best time with me stock e55 last weekend
12.6 sec @ 181km/h.
me times are getting better
started of with 13.6;13.3;13flat;12;98;12.8;and finally 12.6sec
hope to drop in the low 12s pretty soon
12.6 sec @ 181km/h.
05 E55, R33 GTR, R33 GTS-t
Sounds good!
More details please!!! Launch methods for each of the times, ambient temps, suspension/tranny settings, etc?!
is there a factory 1/4 ET claim?
Originally Posted by sly55
Sounds good!
that is all the claim available from factory.
2.i had 2 runs with the esp on and the gear in d.
lights turned green put my foot down and planted it.
it stalls for a split sec then launches
both runs where a 12.8 sec @ 180 km/h
3.best run was.
put esp off
put it into manual mode 1st gear got into the water put my foot on the brakes and pressed the accelerater to warm the tyres .
the car spins on the spot to warm the tyres.u can spin it on the spot up to 100km/h
then i did a few burnouts on the dry to warm the tyres.
launch-manual mode 1st gear esp off
lights turned green i planted my foot and changed the gears on the steering wheel @ 5800 rmp that is when it claims to make the most power
final result was 12.6 sec @181 km/h
from a stock e55 which i personally think is execellent.
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
12.6 sec @ 181km/h.
12.6 sec @ 181km/h.
YEarrrgh me matey, me E55 will sail the seven seas in search of me best quarter mile time! Me thinks the kraken be after me engine!!
Sorry, had to do it.
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Sorry, had to do it.![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
tell me mate did u race u supra???
what times or specs u have???
540 6spd
it was not down under
it was @ sunny south africa
thinking of building meself one fast supra!!!
The motor's fully built, from a race ported head with a full titanium valvetrain with oversized valves to higher (yes, higher) compression so I get more low end torque. Rods, pistons, the works, with a full fuel system and 1,000cc injectors and a 76mm Dual Ball Bearing Turbo.
If you're going to build a supra, I suggest you put a medium sized single turbo on it, 720cc injectors and have a day. No need to really build the entire engine unless you want to make insane power. Stock block supras will run 500whp all day long and not break.
She's not really a track queen because I'm afraid to break anything. The motor cost so much to build that I baby it. I think that was my mistake.
"IF U DONT BREAK U DONT MAKE POWER"
