HID Fog Lights
w211 AMG
HID Fog Lights
I just got HID fog lights installed but they flicker when ever I turn the car on. When the car is off it is fine. Do any of you guys know what the problem is? Do I need to get it reset from the dealership? Any help would be greatly apreciated. Thanks!
2004 E320
Hochi, did you get your HID kit from CarLab? I'm experiencing the same problem only when I turn on my foggies. It flickers for 30 seconds then goes away. There is a fix to it from what I recall in the instructions. Will check when I get home.
07 Z06, 08 Rover Sport, 03 Dmax, 13 Diavel
i have a McCulloch kit i bought about 2 yrs ago. it also does the flickering when i turn it on and it was due to a loose connection. I would double check them all in case. Good luck!
Aj
Aj
w211 AMG
All of the connections are on securely. They only start flickering when I turn the car on. W211Ryda please pm me when you get a chance. They look so nice when they are on. Too bad I can't drive with them on yet.
1 Post
2004 S55 AMG
It is the hid kit. I had the same problem with installing hid on my friends 300C. Mercedes voltage is not constance. There are hid kits sold that fix this. I will see if I can find the web site.
off topic but....
What kind of wheels are those in your sig picture and do you have any close ups?
No guys...this is the problem with MB system...System diagnoses and each time decides it self where and how much voltage to send...
I have these problem as well...dealer cant fixed it...
Xenon uses less power the reg.lights and thats is why there is such issues...
The solution to this is it the way you "START" the car...
You turn the ingnition ON, till all the lights on the dashboard are ON...then turn FOG lights switch...they will light propely most of the time and then start the car..."No mailfunctions" signs..
After you start it the car they will work fine but once you switch it off, you have go through same procedure again...
Hope it helps...good luck...
