RENNtech Lowering Module Installed
Found this spot while doing some errands today and I had my point-and-shoot camera with me = mini-photoshoot.
Your car looks sweet.
How long did it take them to install it? Do you like it? I was going to get it done at the same time as my Stage 1, but i decided to leave it for another day.
You don't drive it that low, do you?
i dropped the car off at 10 am and picked it up at 4 pm...they installed it in the passanger footwell under the carpet..its a bit hidden but easy to get to..they did a very clean install.
Looks great man but I would think the ride would be harsh as hell. Again, it looks sick man, just sick.
I'm sure it won't be long before someone steals my idea and makes the next gen ELM that will be fully on the fly (like mine is now)
VRUS, are you listening?? You source the electronics and I'll get the knobs and harness. This could be our first product?? Hehe!
the ride isnt that bad with the car dumped..i've had a couple of slammed vipers, so maybe im just used to the bouncy/rough ride..i actually like it, it seems to handle alot better and the car feels tighter.
im not too keen on the idea of drilling into the module box..the only time im ever going to raise the car is to take it into servicing, and i dont mind taking the extra 5 minutes or so to gain access to the module..but your setup does look ALOT more convenient.
thanks for the compliment.
no rubbing whatsoever..when i picked up the car, the tech. had it set to number 4 (like a 1" drop or so) and it didnt suffice, so, i put it to 0 all the way around and ive had no issues (keeping fingers crossed
)its really easy to use, just unscrew 4 small screws and your on/off switch and the 3 sensor switches are right there..after you select which height you want, you cycle the airmatic system (by pressing the raise/lower button below the shifter) and the car drops to the desired level.
almost reminds me of the old 50-60's bugs when the wheels butterfly in the back from lowering to the ground.
nice looking car. i really need to lower my car.
