Power delivery feels like a 4 cylinder
Old Sep 12, 2006 | 10:43 PM
David Joor's Avatar
I just got a 2003 E55 today and have not had time to really read every thread yet but I am having a big problem. Sometimes the car goes and sometimes the car feels like it is running on 4 cylinders or something. I will have it in sport or manual at 2nd gear and 4 thousand rpms with ESP off; when I mash the pedal it makes engine sound but just doesn't go anywhere. But then 2 minutes later when I try it again it is all power. It almost feels as if timing is being completely retarded. Now the only thing is, the dealership filled it up from a 1/4 tank for me and maybe he put in 87 octane and the ECU is cranking down the timing. Maybe paranoid but sometimes when I goto jump on it I hear what sounds like a ping/knock but then it goes away as it climbs.
Anyone have any ideas if this is just a common low grade gas problem or something I am missing all together. I am so excited minus this little tid bit. I mean, my brothers RS6 is pulling me and I can't have it.
Old Sep 12, 2006 | 10:50 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
your ecu is most likely shutting down the s/c because of high intake air temps which could be a few different things. your car needs to see the dealer.
Old Sep 12, 2006 | 11:28 PM
zdkdeeier493's Avatar
mikey's right. Get that thing in asap. Mine did it too (and still does sometimes) and its the most obnoxious thing ever. Its also quite unsafe because as you get used to the way the car drives, if you try to make a quick lane change or pass somebody or something, the results could be disasterous if you are at 20% power.
Old Sep 12, 2006 | 11:40 PM
David Joor's Avatar
Thanks for the info you two. This is very disappointing to say the least, especially if the problem still slightly exists after you had it fixed. It still has some warranty so I will just be out of my new car for a few days I guess. When the power is there it feels great, I am coming from a 530rwhp Z06 so the luxury is such a nice change but don't hiccups like this again.
Old Sep 12, 2006 | 11:57 PM
jangy's Avatar
2015 S212
Still want to flame me about the '03s?
Old Sep 13, 2006 | 12:08 AM
David Joor's Avatar
So now I am getting the feeling that this is common? Has anyone with the high intake temperatures actually get a permenant fix?
Old Sep 13, 2006 | 12:11 AM
france2112's Avatar
2015 Mercedes-Benz CLS63 AMG S
Intercooler pump is bad!! Happened to me in my 03 CL55. Tell your service adviser what is happening and let him know you think your intercooler pump went bad. Once it is replaced your car will rock again. This is a very very common problem with the 55's across the board. Mercedes AMG builds a great car and puts in a lousy cooling system. Go figure?
Old Sep 13, 2006 | 12:13 AM
Jrocket's Avatar
E55
Sure,whats your take on the 03's? A friend of mine has one and im betting it runs better than my 05.In fact at the track it already did.
glassJAw's Avatar
'01 E55
It could be a lot of things considering the amount components involved in engine power managment and throttle actuation.
Without a DTC read-out or road-test my first guess would be throttle actuator since you said it appears to be completely random and intermittant. But then you mentioned a noise from the engine so it's possible it could be mechanical. Definitely have looked at ASAP. Keep us informed.
Old Sep 13, 2006 | 12:22 AM
chiromikey's Avatar
i think france pretty much nailed it as the ic pump is the most common culprit. have it replaced under warranty (probably in and out the same day if you have a good dealer) and you shouldn't have any more problems.
Old Sep 13, 2006 | 12:27 AM
David Joor's Avatar
I live in Houston and assume the huge dealership here is really nice, at least it looks it. I was driving it very spirited and it would make sense that it would be temperature related because when I drive normally and don't try to go light to light it is always on tap. However I got this car to drive it like it was designed
I will keep an update on what I find out and the results.
Old Sep 13, 2006 | 12:29 AM
Jrocket's Avatar
E55
Too bad your so far away or i could check the DTC's for you.Im thinking SC shut off for what ever reason it is.
Old Sep 13, 2006 | 12:42 AM
jangy's Avatar
2015 S212
I've always agreed that the '03s are faster (engine wise). If you have an '05 and he uses you at the strip, that is one thing. If it is a road course track, then you suck as the '05 and up ahave newer suspension (mostly steering rack). LOL. Just messing.
The '03s are just plagued with issues. When running, they are great....but.
Theres the cooling, ECU takes, and the dreaded SC clutch to worry about amongst a slew of other DTBs.
Old Sep 13, 2006 | 12:44 AM
jangy's Avatar
2015 S212
It is quite common, indeed. BUT, also well known by the techs and can be worked out completely (almost). the only lingering issues are with some current mods. If you stay stock, it can all be worked out. Hope you still have warranty left. If so, let them do their thing. Find a responsive dealer.
Old Sep 13, 2006 | 12:55 AM
mclarenm8d's Avatar
2003 CL55 Kompressor Horizon Blue Metallic
It's probably the heat soak/intercooler pump thing as the others have mentioned.
But another item that's possible that I had issues with is, believe it or not, my CL55 with a weak battery. I'm going to guess that like my CL55, you still have the original battery(ies) from 2003. Systems are similar to yours, plus the following indicators -
1. You may have a sporadic ESP warning.
2. If you blip the throttle in neutral, it may zing up to 4000 RPM and then hold there.
3. The supercharger may actually stay engaged even though you are not on the throttle (sidebar - this got me thinking that we could figure out a way to keep the SC engaged all the time).
4. You will not have a check engine light on.
I was out in the middle of nowhere when this happened to me, and I guess I am "lucky" that I've owned enough Motronic cars to guess and get this right the first time. The four indicators I mention kinda' go along with Glassjaw's comment on power management/electronic throttle control (ETC). For whatever reason, what the ECU thinks is the juice getting through the ETC isn't what is happening.
So, if they start giving you the run-around and can't get it fixed see if they will change out the battery(ies) for you.
Old Sep 13, 2006 | 01:30 AM
Jrocket's Avatar
E55
Quit kicking me with those Flinstone toes,Im fragile!
Old Sep 13, 2006 | 09:23 AM
V12Godspeed's Avatar
Your worst nightmare...
two words, lol! Intercooler- Pump!, My car died on Wide open throtle, while racing a damn porsche in the Highway, man that was frustrating...It felt like I had a corolla, this happens when the supercharger coolant is too high, the computer shuts off the supercharger so it does not get dburned out, when the temperature stabilizes itself it turns it right back on. I took my car to the dealer and they put a brand new one under factory, my car kicks ***, and does not die, I could leave it WOT for a minute or two, no defects.
Old Sep 13, 2006 | 09:58 AM
Coalman's Avatar
2003 E55 K1
I have a 2003 and experienced similar problems after ECU reflash. Intermittent nature of your problem suggests problem is ECU. I would bet not intake temp. Have it checked out. I ended up getting new ECU, belts and pulley.
Old Sep 13, 2006 | 11:22 AM
David Joor's Avatar
I took it to the dealer this morning and was very pleased with the service. I told my rep what was happening and the first words were, is it a 55. I asked if he had experience with this issue and he confirmed he has had a few come in and it will all be covered under warranty. I scheduled an appointment for tomorrow so I can get a loaner car.
This morning the car is fine, as long as I am not going light to light, but what fun is that? I will keep you all informed and thanks so much for the insight.
Old Sep 13, 2006 | 04:02 PM
RJC's Avatar
RJC
Various
Great looking SL600 but lose the Autohaus license frame...
Where are you in S Fl? I'm in east Boca.
Old Sep 18, 2006 | 09:35 PM
David Joor's Avatar
Great news, got the car back and it was the intercooler pump. Got to race the RS6 again tonight about 6 times. I got him every run. He had one run where I spun and his power-brake was perfect and he got almost 2 cars on me, by the middle of 3rd I was going by him like he was standing still. The other runs he would get his rear wheel by my door but by the time I shifted 2nd I was in front of him. I am still learning how to launch this torque monster but was getting very consistant by the last 4 runs and the results were always the same, RS6 in the mirror.
Old Sep 18, 2006 | 10:27 PM
chiromikey's Avatar
for those of us that have had the ic pump go bad the diagnosis was a no-brainer. unfortunately it does happen often. glad to see you can now consistently beat up on the competition.
