CL65 wheels?
Any opinions?
thnx
If offset is 30 and 31 will I be ok? and ok to lower with that offset?
I am running OEM right now. I run the 18X9 from the rear on the front and a 18X9.5 from a CLS500 in the rear. The front is PERFECT with a 275 on it. The rear needs more et. I shaved an extra 1/8th inch off, but it is still close on EXTEREME compression.
I will have no rubbing at all after the switch. I am paying so I can play. HRE will be fitting the car to get the optimal offset. It has been too hard to find rims with the offsets I want. It is really a win win for everyone. I get the wheels I want and HRE gets the stats for the most aggressive size on our cars so they can sell it to everyone (not just locals).
Then I doubt you'd have any issues even if you did lower it. My rubbing doesn't really matter about ride height. If it rubs it rubs in the turns only. This new RENNtech module has been great for testing different levels / rake. It is amazing how the handling can be changed by a simple switch.
