Red Puddle Under Car
Old Sep 26, 2006 | 02:34 AM
Akara1's Avatar
Sold
Just got back from my honeymoon to an ugly surprise. Theres a puddle of red fluid under my car that extends out past the front of the car. Red must be either transmission or power steering right? I dont want to start the car for fear of damagind something. Any thoughts? The car is an '06 with about 13000 miles on it. Thanks in advance.
Old Sep 26, 2006 | 02:39 AM
IanSL55's Avatar
'10 MB E63, '08 ML550 ('05 E55, '05 SL55, '08 E63 GONE)
That or you tossed up a racoon into your undercarriage (not kidding).
~ Ian
Old Sep 26, 2006 | 02:42 AM
MB Fanatic's Avatar
4 wheels
most likely tranny fluid. Call MBZ and have them tow it to the dealer for you.
Old Sep 26, 2006 | 01:55 PM
Grumpy666's Avatar
Just to be sure, what color is your anti-freeze?
Old Sep 26, 2006 | 02:14 PM
FlyByNight's Avatar
05 E55
exactly... I have two cars with red anti freeze in them...
my E55, however, is green... so who knows...
Loren
Old Sep 26, 2006 | 02:44 PM
2K6E55's Avatar
AMGs
Old Sep 26, 2006 | 02:50 PM
Torquey55's Avatar
2006 E55
Is this what I have to look forward to when I hit 13,000 miles? That's a nice welcome home surprise after a honeymoon.
Old Sep 26, 2006 | 04:45 PM
Grumpy666's Avatar
Wait 'till the honeymoon's over - he's in for an even bigger surprise . . .
Old Sep 26, 2006 | 05:20 PM
mclarenm8d's Avatar
2003 CL55 Kompressor Horizon Blue Metallic
I'm guessing the same, and second the recommendation. Going a step further, might be a tranny cooling line come loose.
My CL55 may be a little different (tandem power steering/ABC pump), but the power steering fluid is pentosin (blue green). Anti-freeze is blue-green as well.
Old Sep 28, 2006 | 07:59 PM
FlyByNight's Avatar
05 E55
What did it end up being?????
Old Sep 28, 2006 | 08:09 PM
whoover's Avatar
'19 E63S sedan
You mean you went on your honeymoon without your AMG?
Old Sep 28, 2006 | 08:14 PM
MiamiAMG's Avatar
C63
Same thing happened to my C32 when i first got it in 2001, it's the tranny fluid. I had a defective o-ring which led to the leak, they replaced it & i never had a problem again.
Good luck
p.s. Congrats on the honeymoon!!!
Old Sep 28, 2006 | 08:16 PM
Akara1's Avatar
Sold
I got the car back yesterday. The seal for the transmission electrical plug was leaking.
Old Sep 28, 2006 | 08:18 PM
Akara1's Avatar
Sold
If there were a way to drive it to the caribbean, I probably would have, lol. St. Lucia is probably not the best place for my car though. They drive on the left side of the road and all the cars are right hand drive.
Old Sep 28, 2006 | 08:32 PM
FlyByNight's Avatar
05 E55
wow, that's crazy because that was a common problem in the 05 and earlier units (Kleemann did the TSB on mine when they worked on it in 11/05).
I would have thought they fixed it in the 06 units... that's why I didn't even consider it a possible cause.
But yes, I'm pretty sure that plug has a TSB on it... and I guess they only address it if a problem arises.
Mine tranny was only half full when they found the leak... which overflows into another plastic pan, and not to the ground... until its really bad...
glad you got it worked out...
Loren
Old Sep 28, 2006 | 11:55 PM
vader's Avatar
04 E55
Definitely a TSB on it Loren...mine was done...I recently had a TSB done for new carrier bolts which I assume are the rear end carrier bolts !!
Old Sep 29, 2006 | 06:24 PM
FlyByNight's Avatar
05 E55
yeah, but how wack is it that this TSB has been out since 05, and yet they didn't fix the problems on 06 cars like he has right from the get go... or merely implement the fixed part / plug on all subsequent models?
wacky
Old Sep 29, 2006 | 06:37 PM
vraa's Avatar
Your car is bleeding, get a bandaid.
Old Sep 30, 2006 | 03:42 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
simple solution...see next post
your car is a girl!
Old Sep 30, 2006 | 04:29 PM
Akara1's Avatar
Sold
HAHAHAHA. Thats some funny stuff, lol.
Old Oct 1, 2006 | 04:28 PM
glassJAw's Avatar
'01 E55
The transmission electrical plug leaking trans fluid is a common problem. But with the update plug & seals it shouldn't cause you any more trouble in the future.
Old Dec 9, 2006 | 06:57 PM
psk145's Avatar
2006 E55
crap, my 2006 with 2300 miles on it has a puddle underneath it
luckily it was in my garage which is epoxied, so it was an easy clean up. I left the car in the driveway, but no leaks.
Is there a way to check the fluid level in the transmission? I was planning on taking the car out over the weekend.
Old Dec 8, 2008 | 12:57 PM
TopGun32's Avatar
reviving an old thread...
I'm having the same issue..
so I decided to buy 5 qt's of ATF, new gasket and filter and perform the usual transmission flush.
Looks like the leak is less than before but not gone.
The next step is to get the seal fixed.
anybody have a picture or diagram of this part and the part #.
"The seal for the transmission electrical plug"
Old Dec 8, 2008 | 01:49 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Originally Posted by TopGun32
...anybody have a picture or diagram of this part and the part #.
The original O-ring seals (A015 997 05 45 and A015 997 06 45) are NLA from most MB wholesalers.
Superseded part number is A203 540 02 53.
It’s a straightforward task to R&R the seal. Figure ~one hour of labor from your competent technician.
