Feeler....E63 rotors for E55
the price is actually not that bad compared to alternatives.
Actually, i am also looking at the 030 rotors / control arms. The only issue there is I don't know that they will fit with 18" rims.
For this round, I just wanted an update that was a straight fit just so others may have an option. For myself, I figure pay for this and treat it as a brake job and upgrade calipers and rotors on the next round.
Please let me know ASAP if you think differently, since you have the knowledge on these.
Im Going with the 030 fronts..as I Have 19s and The AMG Multipiece Rims will clear them on the wifes car..and for the $
Its worth it..Complete set up calipers/rotors/pads for $2500.00 (new)
CANNOT DO THE ROTORS FOR THAT..
Now the rears...as the rears take a lot of wear on SBC cars ...
man I wish that I could get something done with the rear swaybar setup. I may just have to get under the rear of her and remove everything to take measurements. But then again I can make one of's but I want to pass along the treats to everyone here in the forum.
im pretty sure it would
jangy, remember, JRocket is waiting
The lean that you talk about actually helps keep the car in line, since it puts more weight on the outside tire. Keeping the rear flat would put less weight on the outside tire and would encourage it to step out. It's the same principal behind the softer rear springs to launch a drag racer, while stiff springs would just allow the tires to spin all day long.
Be careful though, as just popping in the biggest bar you can find can upset the balance of the car. You don't want to be sliding at 25mph in the rain (it sucks when you don't expect it). Everything has to remain proportionate.
