How to change time on the clock??
Old Nov 2, 2006 | 07:40 PM
toro4me's Avatar
From: New York, Shanghai, Hongkong, Bangkok, Penang
honduh, bimmer, bEnz, ferrari and etc
the only user manual i have ever read on any of my cars, is the Ferrari one.
so pls no smart *** comment about referring to user manual.
just need a quick answer on how to change time back 1 hr on the analog clock left to the speedo. i looked allover and don't see a ***/etc to adjust. i actually changed the digital time on the nav unit and thinking maybe the benz is so high tech and the analog clock will adjust itself LOL.
so wats the deal?
Old Nov 2, 2006 | 07:51 PM
jangy's Avatar
2015 S212
You shouldn't have to do it at all.
Go into the menu under services and make sure it says to link the nav to the dial. Then all should be good to go. I never change mine. Somehow, it knows...
Old Nov 2, 2006 | 07:52 PM
jangy's Avatar
2015 S212
By the way, dunno what is sexier...the girl by the ferrari or the E55
Old Nov 2, 2006 | 08:00 PM
toro4me's Avatar
ok i did set the time on nav unit, but prolly did not check the "LINK" option. will try that later.
thx playa.
Old Nov 2, 2006 | 08:13 PM
kiwie55amg's Avatar
2004 E55
The GPS automatically sets the time (pretty sure)
Old Nov 2, 2006 | 08:16 PM
tsmithmd's Avatar
You can set the clock to go to the same time as the Nav by selecting the synchronize head unit option under the settings menu (get to this through the steering wheel controls - date and time). You can also set the analog clock "manually" through the same menu.
Old Nov 3, 2006 | 02:00 AM
Hardrivr's Avatar
2004 E55
if you TRULY don't know... you have a problem! Do you want to RIDE or DRIVE? but will have admit... he does have some quality choices...
Old Nov 3, 2006 | 11:35 AM
PDC's Avatar
PDC
2006 SL65 ///AMG - GONE BUT NOT FORGOTTEN: 2005 E55; 2002 ML55; 2001 CLK55; 1992 BMW 850i; 1991 M5
Clock
Heck with the clock. One look at the girl in front of the Ferrari, and I know EXACTLY what time it is.
Old Nov 3, 2006 | 12:01 PM
whoover's Avatar
'19 E63S sedan
My S figures out DST but my C needs to be told. If yours is like my C, you go into the Service menu and reselect your time zone. It seems like it wouldn't do anything useful, except the next screen allows you to select DST or standard time. Select standard and your clock resets.
Don't go down the manual adjustment path if you have nav. You want the time to come from the GPS system. It's accurate to a fraction of a microsecond.
Old Nov 3, 2006 | 02:06 PM
toro4me's Avatar
thank u all.
i got it working, i set the clock to link with Nav unit, and adjusted nav time, the clock started to spin, pretty cool.
Old Nov 4, 2006 | 11:36 PM
WBRCobra's Avatar
Clock Setting
Okay, I know you already got your clock set, but since I previously went through the trouble to type this out (since I never can remember how to reset the clock) I thought I'd post anyhow...
Clock Setting:
Turn car on; leave car in park and look at steering wheel; press the top “next page” button on the left side of the steering wheel until it says “settings” and shows the “hour and minutes” (once you get to "settings" you may have to use the down arrow to get to hours and minutes if this is not already displayed). Then, press the up arrow and it should move to “hour." Press the +/- keys to increase or decrease the hour. Then, press the up arrow again to move to “minutes.” Press the +/- keys to increase or decrease the minutes. Once minutes are set, press the black button to the left of the instrument cluster and hold down until the clock scrolls to the correct time.
(you may not have to hold down the button - it normally moves on it's own until fully set).
Old Nov 6, 2006 | 03:11 PM
zoink's Avatar
1989 Toyota Tercel EZ - dyno'd @ 70whp/77wtq
I'm the other way around... One look at the girl in front of the Ferrari, and I FORGET what time it is. Everything stands still...
Ferrari has owner's manual? Isn't everything still manual? j/k
