Bridgestone Tires
Bridgestone Tires
Anyone have experiece with Bridgestone RE960's? I am starting to shop for new tires and the guy at the shop was raving about these. I was originally going to go with the PS2 or P-Zero's but the guy said these performed better and were quieter.
And Bridgestone says they will guarantee 40K miles on them which seems very bizarre for a Y rated tire.
Mike
Mike
Got the RE050A's and they are much better than the conti's ... especially in the dry ...
Cannot really say about the 960's but I would probably get the 050's again.
13 SL63
Mike
Mike
Mike
Mike
Mike,
There is NO WAY performance tires last 40K... They are pulling your legs!
I don't need an all season tire as the car doesn't see the roads much when it is raining so I am looking for good suggestions as well.
Mostly trying to see which way most went when buying new tires.
Some people dispraise the ContiSportContact2 tires but I think they should have a look at some tests. Yes, a Michelin PilotSport2 or Bridgestone RE050A does some better on dry than the Contis but SportContact2 is a much more all-round tire. It beats them all on wet in terms of traction and handling and has much more aquaplanning tolerance. Also Pirelli PZero Nero has a similar character but Michelin and Bridgestone really suck on wet.
If you say you never go out when it's raining then it's a different story of course. On sole dry roads PS2 or RE050A would be better choice.
13 SL63
2000 e55 amg
Local tire shop tried to sell me on the 960's as they are listed as the replacement for the Bridgestone Potenza S-03's which have been discontinued. I opted for the Bridgestone Potenza RE050A's after consulting with an expert. They are an excellent replacement high performance summer tire to the S-03's. I have put about 5,000 miles on them. Grip is excellent. You will give up a lot of performance if you go with the all season 960's. A simple test would be to put the tires side by side and simply step on the sidewall. You will notice a significant difference in the rigidness of the sidewalls. Although the RE050's are a bit noise, they are a much better option.
