E63 mods, more noise
It does sound better, but like mogz remarked, I want more.
My question is, If you remove the resonator and then decide to go to an aftermarket exhaust, I.E, eisenhauf, race or street, how much louder does it make it or does it even make much difference, with the resonator removed.
It would be a good option if it made it sound better. I just hate to hack all this stuff off and find out I should have just bit off on an eisenhauf race in the first place.
Did your guy at merc say it would make a big difference in the sound?
As far as cats go. You can cut out the secondary ones without any error code issues. The first cats will need an ecu mod or extensive faking of a sensor to avoid the error code. Many here have done it, although i won't just because of the MB coding battles going on. Keep another thing in mind. Cutting out the cats and going with an Eis-Race is actually going to lower your power in the lower RPMs. Actually, I never did understand why people would do that since I am stricktly performance oriented. If all you want is sound, why not just get the mufflers replaced? It is much cheaper and it adds any level of sound you want. Another alternative is to have your OEM mufflers "punched". Most muffler shops can do it and it will add sound (lots) AND power (little). I am considering cutting the secondary cats and having my OEM mufflers punched, so we'll see. If you really want it loud, get Glass Packs. They are basically nothing but straight pipes with some insulation. LOUD is an undestatement plus they are only about $50 each.
Don't just follow the lead. Decide what you want and then get it.
Like many I too want a deeper, throatier sound without sounding like a racer and without droning. I simply will not tolerate droning...that's how I ended up with a 5k Europipe system on my 996TT. I really do not wish to repeat that expensive lesson on my E55
Do you or others have experience with 'punching out' the mufflers? Is there cabin resonance or droning?
Thanks for your thoughts.
What have some of you 55 guy's put on your rigs?
