Check Engine - Thermostat
Did you loose or gain performance that you could tell?
P.S. Had Pirelli P-Zero/Nero M&S tires installed yesterday and stepped up to 275s in the rear. My dealership had a helluva time getting the rears mounted; said it was difficult to fit the 275-35 on a 9" wide rim. I've never heard of such a thing before, I thought 9" was plenty of real estate to mount a 275(?)
While I was driving it on the freeway with the CEL on, my supercharger cut completely out for a mile or so, then came back on and didn't flake out again. I've been feeling like the car had lost some of its high-end power for a while now, but this is the first time I've ever had the supercharger completely cut out on me. It felt like I was driving a 300HP car (probably was!). Now for my question... after replacing the thermostat the dealer found that the Air Charge Circulation Pump (part # 00050000386) is also malfunctioning. Is this the same thing as the IC pump that several people on the forum have had replaced? Could it be responsible for moderate loss of power under normal driving conditions?
