HP Ratings
414 *multiplied* by .18 = 74.52 add that to the original 414 rwhp & you get 488.52....
That's the way I was tuaght anyway, please explain better if I've been wrong thanks
Edit: I see what your are doing but I don't know which is correct they both make sense....
Your way 505 multiplied by .18 = 90.9 add that to 414 = 504.9
414 * 1.18 = 488.52. That's not the same taking 18% from the crank HP number. You're adding 18% of the RWHP number to the RWHP. 18% of a smaller number is of course smaller than the 18% of a larger number.
400 * .18 = 72 + 350 rwhp = 422 Crank HP C6 w/ 432 crank torque though I'd like to believe this I don't think it's true....Hope so though!!
She is damned quick! they did report the new Z06 was underrated from GM so maybe ...mine to..
What you really want to do is:
414/507=81.6%
100% - 81.6% = 18.3% loss from crank to wheel which is what is to be expected. I have heard of others getting 425 after about 3000 miles. This car only has 900 miles on it.
The discussion is about the accuracy of HP ratings, not 63 VS 55, and even if you consider them equal, either the 55 makes more than 469 HP, or the E63 makes less than 507.
The discussion is about the accuracy of HP ratings, not 63 VS 55, and even if you consider them equal, either the 55 makes more than 469 HP, or the E63 makes less than 507.SL55 was rated at 493HP and E55 was rated at 469HP.
I have dynoed ten SLs and over 30 E55s - on the Dynojet, both cars are in mid420s RWHP.
I usually like to use 17% drivetrain loss. So to find out flywheel HP from wheel HP, I simply divide WHP by 0.83.
So if CLS63 is making 415 at the wheels, than we have 414/0.83 = 499HP. Considering that CLS63 still has 900 miles, IMHO AMGs 507HP rating is right on.
This deffinitely falls in line w/rumors of GM understating Z06 HP w/Stock C6 Z06 rwhp of 445-465 on dynos I've seen at the Vette forum, that = 536-560 crank HP stock ohh damn! no wonder there so kick-***
Edit there even higher I forgot to lower the drive line % loss due to the Z06 is manual...
lets see...
Drivetrain eficiency
IAT
Ambient
AC on / off
Alternator Load
Fuel Octane
Fuel Mapping program
Dyno Type
Tyre grip on dyno
S/C Belt slippage (if present)
Gearing differences / tranny and diff.
And there are probably loads more ...
lets see...
IAT
Ambient
AC on / off
Alternator Load
Fuel Octane
Dyno Type
Tyre grip on dyno
