Anyone challenge the ecu speed limit?
#51
///E63V10 ///F80CS ///Can-Am X3 XRS
What do you recommend boss? Going in for surgery under hood soon so the last thing I need to worry about on the road is blown tires.
#52
2015 S212
The Yokos are great tires, but you should make sure your rims aren't to blame as well. Install is critical on those sizes, too. Even at 140, there is no reason why a tire would pull off the rim. I've had that happen once and it was the bead not being seated properly on install.
Dude, glad you are OK. I assume it was a rear wheel?
Is the surgery for sure? I'm only doing it cause of you and Jeff.
#54
2015 S212
I just talked to James. I'm dropping by tommorrow to lock it down. I'm also trying to get one more cat from Vegas to get in, so we get a better deal (slightly, but every bit helps).
Glad you are safe. That's always scary **** when that happens, especially since you've been paranoid of that setup anyway.
