If You Could Only do 2 Mods ...
(I did that for all the holierthanthou members).First off lets review your picks:
1. LSD?? I know it makes absolutely no difference at the 1/4 mile track but on the street with irregular surfaces it may alter a race outcome.
2. IC mod. This mod would only be a factor if you have done repeated runs or your car is running hot.
Okay, if you are looking for stoplight dominance in your E55 the two best investments you can make are:
1. Very sticky tires and I'm not talking about drag radials that you have to heat up. I'm talking about very gummy autocross tires.
2. Take a few lessons at your local drag-way to learn how to launch the E55. Pull consistent 1.6sec 60ft times and no one will touch you.
Now, if your looking for dominance on the highway, the two best mods are ECU/belt and then headers or possibly ultralight wheels.
If we wanna talk "bang for the buck", I say:
1- get a pair of rear rims and put them on the front.
2- get a nice sticky set of tires.
Total cost will be $2500 max, and it will easily SMOKE an OEM car with the upgrades you mentioned.
If tires aren't considered a mod, then yes, get a Quaife as well.
I've let a few people drive my car before and after since it only takes a few minutes to install and they've since ordered thier own for thier E500s and various other mercedes cars.
I had "heat soak" numerous times when my car was bone stock. It was really frustrating to have the supercharger just stop making booost completely. I think it all depends on the climate (I live in Texas). Since my IC upgrade and other mods (including K2) I've had no issues.
If someone has ever experienced heat soak then I would recommend the IC upgrade. However, I'm not sure if I'd waste my money if there had never been any heat soak issues.
Big Pulley (ASP)
TB & ECU (doing airbox at same time)
Heat exchanger - patiently waiting for VRUS to complete his testing
Headers (still no clarity on whether Evosports' will fit RHD so
)Quaife (and 2.82 diff ratio at same time)
AirBox (if you did not do it at the TB point)
A set of Bleeks heads.....
and finally a set of SLR intercoolers and a cutout CF bonnet so they can peek out....
This is my pecking order....
That car will be an absolute monster
