ASP pullies or not...
Old Jan 22, 2007 | 03:16 PM
Finnish C32's Avatar
W211 E55AMG
hello.
My '03 E55 has around 40tml now and couple '06 upgrades (ic-pump and clutch-pack) and my car is going out of extended-warranty next year.
Im thinking to get ASP pullies and maybe a headers before its time to look other daily...trying to save for '07 Gallardo Spyder should i be concerned about sc or anything if i do those mods with such high miles on my car? i chance my oils well under 10k miles periods etc. if i blow my motor or something can i chance normal pullies back without my stealer will see it?
Thanks for all information and sorry my bad english
Old Jan 22, 2007 | 06:21 PM
DFW01E55's Avatar
'14 ML BT
40k miles doesn't seem high but if there are any inherent weaknesses in the engine, the addition of a pulley may help them get noticed sooner.
I understand that warranty issues are different in Europe so you need qualified feedback, not guess work from this side of the pond.
My vote is, save your money, cut your risk and get the Spyder sooner.
Old Jan 22, 2007 | 06:38 PM
W211 E55AMG
Thanks for reply DFW01E55,
I know it has sense to cut risks but still i have one full year to left....a little more power is welcome but, ASP pullies is only something like 1k usd installed that is tempting me.....
btw. you ASP users Is there a REAL SOTP feeling when accelerating in higher speeds or is that heat soak killing the beast alot sooner?
Thanks.
Old Jan 22, 2007 | 07:15 PM
ROCKETW19's Avatar
06 EuroElites E55
Thanks.
if you get the asp pullys i would also get the IC with heat exchanger upgrade your car will run hot quick if not.
Old Jan 22, 2007 | 07:59 PM
W211 E55AMG
ROCKETW19, thats what i thought....so just a pulley mod without coolant mods is near stupid?
Old Jan 22, 2007 | 08:51 PM
BMWEATR's Avatar
211 E55(sold) & 80cc shifter kart
You'll get about 10 or so seconds of full ASP power then the heat build up will make your hp go the wrong way. ic upgrade is the only way to go.
Old Jan 22, 2007 | 08:55 PM
jangy's Avatar
2015 S212
I'd spend the money and get it done right (i.e. RennTech). I'd hate to deal with with heating, etc issues. I say no to ASP, but up to you.
Old Jan 22, 2007 | 09:15 PM
DFW01E55's Avatar
'14 ML BT
Finn, I've got the ASP pulley only and have had no heat soak issues - zero. In the interest of fairness, I should comment that it is winter and my experience may change in the 38c+ Dallas summer.
Here's a little testimony to the ASP pulley, RennTech is coming out with a larger pulley - it may be larger than ASP (or smaller) but it may very well be a response to the big numbers that come from an ASP.
And yes, SOTP difference is big. When you pick up 80 lbs of torque, it will be noticed.
Old Jan 22, 2007 | 10:02 PM
jangy's Avatar
2015 S212
True that, Renntech is coming out with bigger, but it will only be available in conjunction with the IC upgrade. That isn't simple marketing. It is a necessity. I have no doubt that the ASP pulley can be used as a component of a great upgrade (assuming it doesn't shred belts like some others), but you have to do it right or you'll stress the car and kill the motor at some point. Either that or get it and don't really use it?
Old Jan 22, 2007 | 10:49 PM
Jrocket's Avatar
E55
Thats a pretty bold statement.Do you have any proof that using ASP is doing it the wrong way?I understand your all fired up about getting Renns stuff,but to imply that ASP is'nt the right way is a bit off.
Old Jan 22, 2007 | 10:56 PM
jangy's Avatar
2015 S212
No I don't. Actually, agan it isn't the pulley alone I am against. I just think if you are going to go to an extreme, which the ASP is, then you should also upgrade the peripherals to match it. I have nothing against the ASP pulley, but then where is the support for the ECU? Where is the cooling that is needed? That's all.
Old Jan 22, 2007 | 11:01 PM
Jrocket's Avatar
E55
I got ya.I dont think it is extremely needed for either of those 2 items unless you go beyond the pulley,such as headers,cams,etc.
I would be curious to see what your car dynos with Renn pulley alone and no Renn ecu.then add the ecu tune and dyno agaon.That would be something I'd be very interested in seeing.
Old Jan 22, 2007 | 11:07 PM
jangy's Avatar
2015 S212
How interested. i could do it. I just want a good dyno shop, first.
Old Jan 22, 2007 | 11:08 PM
psk145's Avatar
2006 E55
Im actually just getting the RT pulley first, so if James would be willing to get me 3 dyno's, then we can see what the gain is.
psk145's Avatar
2006 E55
thats a big plus. Im a bit taken back by the dyno posted earlier.
Old Jan 22, 2007 | 11:18 PM
Jrocket's Avatar
E55
Good dyno operator is the key.You need somebody thats not in a hurry to get your car in and out.Make sure the temps are the same for each and every pull.This is the only way to see if the true gains.And yes I have always been very curious to see what you actually gain with the tune on top of the pulley.I will be doing this exact test but not for some time,Im either really busy or when the free time comes I like to be lazy.
Old Jan 23, 2007 | 12:05 AM
jangy's Avatar
2015 S212
That was just ugly. Something ain't jiving there.
Old Jan 23, 2007 | 05:56 PM
DChan415's Avatar
AMG's
Thats exactly the point. What people need to understand is that ASP is a pulley company, not a tuner. They're selling you the pulley kit, not an upgrade package. If you're ordering a pulley, you should be competent enough to be able to plan your other upgrades as well.
Old Jan 24, 2007 | 06:29 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
I got the ASP pulley and IAT's do rise prety quick - but have yet to have a SC shut down ... I also need to get a chance to go WOT for more than 5 seconds (these cars are too qquick) to see if teh IAT's plateau or if they keep rising into SC shutdown ... need 0-155mph blast to know for sure.
If you ever think of taking the car to the 'ring or track - forget it heatsoak will kill you ...
I am looking at getting a larger heat exchanger built up here with more hopefully double the area E.fifty.5 had one made up in the UAE - but he never gave us the details of the design ... How about it dude !!!!???
A better pump will also help but larger heatchanger surface area, more water volume and a seperated circuit from the radiatior is a good starting point (i.e. as per Evosport - but instead of using a second heat exchanger replace the OEM one with 1 bigger version.
