Intercooler Upgrade - SLR style
'03 E55, Range Rover Sport Supercharged, Ducati 748R
I think thats a bad place for the filter. The base of the windscreen, aerodynamically, is a low or negative pressure area. Theoretically the airflow is poor and could affect performance. Certainly, there wouldn't be any ram effect at high speed.
that is the RENNTECH I/C set up, and that is an HKS air filter that comes with the SLR style I/C kit, that car was done at DYNOCOMP in Scottsdale, AZ. That car belongs to Ray Durham of the SF Giants. the car also has an ugly hood scoop that takes the air in, but was not pictured in the photo shoot for obivious reasons.
The cowl is an area of high pressure. Good spot.
Your worst nightmare...
why not have someone custom make something like that? Wouldn't it be more affordable. I have a friend with a Turbocharged C36, he special ordered a top mount intercooling system for his engine, it was somewhat 1600 bucks. For us let's say double that...now compared to 15K i'd say that is a great bargain...
Since you guys opened this up for discussion, I'll throw it out there...
That pic is from the article in ML&E.. Those are Renntech's version of an SLR style intercooler setup...
Renntech is selling that setup from anywhere between $18K - $22K USD.. I've heard different numbers within that ballpark but that is the range.
The main issue is that the cores that Renntech uses are not very good... The cores are tiny and have very bad flow. Let's just say that these units were hacked open and the cores were replaced with some much better flowing and LARGER spearco units...
Also, their air induction "solution" for this setup is horrible (slapping an HKS filter back there is nuts!!!!)... Why do you think they had to eventually put a cold air scoop on the hood of that SL55 and hack open the top of the hood??? They should have come up with a better solution for the kind of scratch they are asking for this setup.
We have been working on this project for a while and a few different people are involved in making this happen.. This is the holy grail for cooling systems on the 55K motors.
Let's just say I can make a system available just "like" the one in the picture for under $10K... How much under depends on how many guys we have on board.
If you guys really are interested in something like this, speak up and if we can get another R&D group going just like the Airbox one I can make this happen.. Everyone would have to poney up some deposit money but you can expect a solution that is BETTER than the one in the pic above for under $10K.
The efficiency of a setup like this will greatly increase power. The 4 - 5psi of boost drop we get going through our stock setup will be mostly recovered by using something like this.
So... Who's first??
So... Who's first??
I've been waiting for this one and am definitely in provided it will fit an SL55.
So... Who's first??
So... Who's first??
2003 E55 & 2014 GL550
Hey V, have you confimed yet whether we need the new supercharger for the SLR cooler setup? I know that was the big hurdle that made most of us walk away when exploring this on our own.
If your coolers are anything like the airbox.....this is gonna be scary good!!!
J
J
Of course they will.. All the 55K's will be able to use them otherwise I wouldnt bother.
The issue with the SLR supercharger was that I wanted to get their style of S/C OUTLET which only was available for purchase if you bought the S/C ($11,000 worth )... This is not needed because this application uses a style of outlet similar to the stock setup, minus the core which is present on the stock system, and it has air baffles which direct flow and minimize turbulence.
J
J
CLK63 Black, E350 Wagon, Supercharged Denali, Lotus Elise, Tesla Model 3 Dual-Motor.
So... Who's first??
So... Who's first??
OK Vic, I'm in again...
Everything else Vic has done... has been good...
MachC5
Not necessarily. See this article - these guys are geniuses http://autospeed.drive.com.au/cms/article.html?&A=1023
Now, we have our answer on why Renntech SLR-style coolers are not making as much power as they should.
Look at that HKS (replica?) filter. This is what suffocates this setup.
These foam filters do not flow very well. Many years ago we used pull them off Greddy twin turbo kit for TT Supras and with simple set of K&N cone filters would pick up easy 40RWHP.
On SLR the intake goes forward and picks up air from the huge rectangular filter from the front MB star. On 55s there is no room to run similar setup.
New hood, with 3-4'' added hump in the middle, would be needed to create a proper air box.
'03 G500, '13 G63, '17 GLS63,
I guess what you're trying to say is that in order to get a proper airbox to fit, we have to make the car look butt-ugly
Victor, this is the same problem you will run into trying to make the SLR coolers work properly.
I am so glad you asked.. Let me provide a little more detail for you and the rest of the people reading...
Renntech sells this kit for $16K USD wholesale, $22K Retail (from the info I have). For this money you get Left & Right cooler, modified S/C outlet manifold, 1 HKS filter. THAT'S IT.. They dont even provide a new pump. Now, someone who is putting this on a car with a stock pump will not be happy to find out that they dont even get an upgraded pump for their $22K -- Not the proper way to build a supposed high end kit.
Oh yeah.. On that Renntech Stage 6 car that was in the magazine that had these coolers, they quoted that the car was pushing 620hp.. A little strange I found when Kleemann K4 is right around 620hp. Anyways, this will make more sense when you read further down.
Ok.. now that the pricing and kit contents have been discussed, let's get on to the nitty-gritty.
We slap these things onto a car and do a dyno pull... +25hp.. That's it... +0.5psi of boost (yes. you read that right.. 1/2 pound of boost is all that was recovered according to trusty boost gauge).. We know the stock setup conjests the motor and we loose 5psi, so we were expecting to recoup most of that... NOT THE CASE.
Now we are scratching our heads wondering what the hell is going on.. So, what do you do when you spend $22,000 and you get +25hp (That's just under $1,000 per pony.. not too good) and you just finished tearing apart half your car to install it????
Well, obviously, you take a cutter to them and chop them open to see what is going on in there... My friend had the cores flowed and also had the S/C outlet flowed before cutting them open. The outlet piece was inadequately shaped and didnt provide optimal flow.. This is clearly evident with a petty +25hp dyno reading. My friend was in shock.. When he told me I just laughed.. (Sorry buddy.. Didnt mean to laugh, but I couldnt help it). We were expecting 50hp - 60hp.
For this kit to work properly, the S/C outlet needed to be reworked with proper air vanes and altered shape. As well, the cores on the intake manifolds were small and needed to be replaced with larger units.
I cant believe stuff like this makes it to market... How do you justify charging this kind of money and having this level of quality?? Its almost like they didnt know what to do about the airfilter so someone sitting at a desk said "I know.. lets throw in one of those HKS filter thingies and call it a day.".. LOL..
This all makes sense because I heard that inside info says Renntech is in the process of redesigning this kit... Gee.. You think?
Someone fell asleep at the R&D wheel.. Seriously.
