Finally in the tens (10.745 @ 132.21)
That's funny. I assumed that's why your dial is a 12.00 on the timeslip
Did they hassle you when you picked up your 10 second slip? You need to get to a private track rental, they're usually pretty relaxed about tech on private days.Not even close - I keep going back and forth on some details. I have most of the parts, still working on bottom end and fuel system.
These are the boxes from Australia that I received recently
Back at you. You went ten's, like what feels like, five years ago before all the hoopla.
Did they hassle you when you picked up your 10 second slip? You need to get to a private track rental, they're usually pretty relaxed about tech on private days.These are the boxes from Australia that I received recently
Wayne does that kit mount in the rear of the car or under the headers ?
Yeah, I figured they wouldn't be too happy. Even worse since they'd already warned you.
It's a front/low mount. I'm not a fan of the rear mount setups. It's made by APS. Here is a picture of the turbo setup. And a link to their website - http://www.airpowersystems.com.au/corvette/c5.htm
Do you have a roll bar in your car? I thought NHRA rules required a roll bar if you run faster than 11.5s. Low 11s probably could sneak by, but how did you run a 10.75 without a roll bar?? Did they say anything when you picked up your slip?
We are there pretty often so they are kind of lenient with us and they let some things slide. Our other buddy Ricky ran 11.29 and they didn't hassle him too much either.Two white E55's haulin ***
I assume that was his last run of the day..
. The Z was on drag radials but wasn't hooking up to good.
Crongrats again on your runs.
from the official. Rentals from now on.Thanks Dragon. The only problem now is i want to go faster on motor. Which means more money.
http://www.dragtimes.com/2005-Merced...deos-7835.html
Are you using any sort of activation, other than a button?
When I was spraying, I'd use a master arming switch -> wot switch -> window switch - to activate the nitrous. This made sure I wouldn't spray too low, but it makes tuning launches a little easier when you spray at the same RPM each time (rather than hitting a button manually).
What do you think?
What do you think?
Not sure on the RPM pickup, but you definitely want a window switch. You don't want to spray too low or you risk a backfire. I'd start at WOT/3000rpm and then move it down from there. With the stock converter, you don't want to spray out of the hole. There's a couple .10 in spraying out of the hole, but you'd need a looser converter to do it.
