*** Intercooler Project ***
Old Jun 15, 2007 | 04:13 PM
  #76
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
Victor, I might have an E55 interested in the setup.
Old Jun 15, 2007 | 09:07 PM
  #77
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Laminora Condensing Tubes
WoW. I've been on the road for 2 weeks . and lots of good info has transpirted. The laminora condensing tubes that where shown by BrianS are the same style that Kleemann uses in the upper part of their intake manifold on their Kompressor kit. they are really good pieces.
Old Jun 17, 2007 | 12:34 PM
  #78
E55 RUSS's Avatar
E55K
Originally Posted by vrus
Tonight I'll post a pic of the actual spacer kit.. I think I am going to include them in all the TB kits from now on.. Might as well install them when you put the TB in.
Victor,
What are those Spacers for ??? Isf you say that people should install them with TB then I need a set for ME as well, so I install them with TB...
Old Jun 17, 2007 | 01:27 PM
  #79
TooManyHobbies's Avatar
Originally Posted by E55 RUSS
Victor,
Phenolic spacers act as an insulator between different engine parts. It's often used between the IM and the block or the TB and IM to prevent the transfer of heat between parts. On my prior turbo cars, pre phenolic as others have mentioned, you could leave skin on the IM, afterwards, it would be cool to the touch. The effects become increased when you have temp sensors in the IM for example and they see a much cooler intake charge due to less heat transfer, regardless of block temp.
Old Jun 17, 2007 | 03:01 PM
  #80
rflow306's Avatar
2005 E 55
Originally Posted by ROCKETW19
oh i tryed very hard no one would do it. they seemed so scared im scared now.
i found a shop that does the crazyest things to BMWs discovery-automotive.com they even told me hell no.
They will put nitrous on those head gasket time bombs but they won't do an e55.
Old Jun 18, 2007 | 12:33 AM
  #81
vrus's Avatar
2003 E55 AMG
Here are a couple of shots of the phenolics... The kit includes everything you see in the pic and I will include 4 M.B. gaskets as well (2 for each side) that sandwich the phenolic material and seal it on either side. So, you get 2 phenolic spacers, 10 stainless ARP bolts, 10 washers, 4 MB gaskets.
The phenolics were made 5mm thick as shown in Pic #2.
I am going to add these as part of the 80mm TB kit to make it a complete solution. I made 20 sets of these because I wanted to offer something to the guys that had to rip out their phenolics in order to install my CF airbox.. That was the main driving force behind doing this.. BUT, the main benefit at this point is that it will give you a complete thermal break between the bottom block and the top half of the motor.. The S/C & surge tanks should both see a nice temp drop with these installed.
I just want to add that most people who want a simple & quick solution should purchase the Evosport offerings.. If you are in a position where the top half of the motor has to come out (to do 80mm TB or heads or something else) then this solution would be better for you.
Old Jun 18, 2007 | 12:37 AM
  #82
vrus's Avatar
2003 E55 AMG
Mike,
I will put 1 set aside for you.. I'll PM you the info once I have everything ready that you asked me for..
Victor,
Old Jun 18, 2007 | 01:19 AM
  #83
E55 RUSS's Avatar
E55K
Thank you Victor,
I would be waiting impaitinatey, hope its going to happend soon (this week)
Lost to LPE Z06 in 1/4 just by 2 cars...If I would have TB already I would probably beat him...
Mike,
Old Aug 7, 2007 | 11:08 AM
  #84
SleeperX's Avatar
E55
Victor,
How can I get a set of your phenolic spacers? How much are they?
Old Aug 7, 2007 | 11:09 AM
  #85
vrus's Avatar
2003 E55 AMG
PM sent.
Originally Posted by SleeperX
Victor,
Old Aug 7, 2007 | 02:37 PM
  #86
StealthAuto's Avatar
Cobra/E55
Awesome work bro!!!
-Aaron
Old Dec 23, 2008 | 02:50 PM
  #87
aleksandar1099's Avatar
Top Answer: 1
Mercedes
sorry to bring back an old thread.....
What ever happened to this project?
Old Dec 24, 2008 | 08:24 PM
  #88
e55 baller's Avatar
W221 S65 AMG
Below is a preliminary pic of what the CF airbox system will sort of look like for the SLR intercooler setup. Those crappy black plastic tubes you see... Well, those will be done in CF!!!
This should make the engine bay look sweet with those nice SLR coolers..
Victor,
How far off are we from production (4 months?) and what do you estimate the rwhp and cost to be (40 whp and 6K)? Looks like this is the mod to get a bunch of us running high 10s.
