Track result @ The Q tonight!
Jay took a run or two to get the Drag radials dialed in and also heated up. I wasn't too happy with his first or second burnouts or his launch reactions. But man, after that, had the thing dialed in. i was very proud. He was hitting the lights perfect and blasting out of the gate! I do have some video footage that i will post later (gotta upload first) and it clearly shows his improvement form well over 9 seconds on his first run. He was basically nocking a tenth of a second off each run. Very well done Jay!! You represented us well.
12 seconds for an E55 with NoNameTech Stage 1 may not be that impressive (as a stock E55 is "supposed" to run those numbers), but Jay's car was in full effect. No way would a stock E55 pull those numbers at this track. It is historically known as a slow track (as are most in our immediate area). I'm pretty confident that Jay would have run some sweet times at a track back east or up north, where the overall numbers are better. He mentioned the 996TT. It was getting 9.2 second runs, so it was not even close!!
I'll be in LA on Friday night meet up?
Also regular westcoast NON SEA LEVEL TRACKS E55's in stock trim run 12.50-12.70' all those sub 12 runs and 12.00-12.20 1/4's in E55k STOCK are only at those super SEA LEVEL tracks, even Ranger the great C6 Z06 driver captured all his best times at those famous great! SEA LEVEL running tracks, 10.85 no one else in the west or track w/higher DA can recreate those #'s stock.
Just had to add that, and I've been still trying to meet up w/Vadim for weeks?? others have tried as well he always has school or something damnit!
I gave him carte blanche! anytime anywhere to see how the Vette will do against E55k stock, also got 2, 63 amg locals cell #'s going to try n set something up this Friday!!!!! 1 of 'em got to show
Maybe you can come out?
This is almost Gustav stuff. This guy is in our neck of the woods. I just don't buy they hole stock bit. No way no how. The guy has increased his mph with every pass? This is the first car I've ever seen bolt on drag radials and he ran a faster mph, not by 1 tick but 3-4 mph? You aren't going to gain that kind of mph by bolting on tires. Generally speaking your mph will go down as you eat up more track and get there quicker not go up.
My MPH did not go down with my quickest e.t. To the contrary, it went up. My car has run a 12.2 @ 115.X, and an 11.9 @ 117.x.
The only thing close to BS about it is when everyone assumes that any Z06 is going to run 10's on DR's and low 11's bone stock no matter who is driving it. It sure can be done. I have seen it done. But you need to be a hell of a driver to do it. Ranger, DrRon and some others from the vette boards can do it. I know I can't.
Still - no matter how you slice it - that car can move.
Trying to recall his explanation, on runs with a difference of about 2,000 in DA (minus 500 to plus 1500) his e.t difference was 3/00's of a second. I was surprised to hear that. But seeing how meticulous he is in his data collection, I believe him.
One thing to keep in mind is that the da will change throughout the day so teams usually check it at the starting line before a pass.
I'm not arguing with you about the general correlation between e/t's and traps. That was my belief as well. But I have my own time slips that show me running both faster and quicker when my car hooks. Next time I go to e-town, I will use the same launch technique that got me my 11.90's at Atco and see how my time and speeds compare to other e-town runs.
What up dude. Give me another week or so and your dreams to race a stock E55 can come true.
On a run where I went throught the 1/8th in 7.751 secs @ 91.56 mph, I finished with an 11.986 @ 117.22. On another run where I ran through at 7.759 sec @ 91.01, I finished with a 12.019 @ 116.60
I think your run was probably a 12.0 run. Nice.
I do a burnout in the waterbox. If you can back into it, that method is better. Obviously, you need to turn off the ESP to do your burnout. Put the ESP back on when you're done.
Now the key is to relax. Unless you are running brackets, what the guy next to you does is not really important. So worry about your launch, and not your "race".
Line up. DO NOT PRELOAD THE TRANSMISSION. Unless you are running DR's, you will just spin or trip the ESP and bog. When you are ready to go, just release the brake and roll quickly into the throttle. Don't stomp the gas, but get to the floorboard within a half second. Then hold on. Make sure that you are completely off the brakes before flooring it.
The approach is counterintuitive, because you are always wanting to preload a bit as the lights start running down the tree. But there is so much torque down there that you can launch the thing at idle and still blow out of the gate.
Good luck.
his DA for that 10.8 run was -850.....
http://www.dragtimes.com/2006-Chevro...pecs-8071.html
Good luck.
