AMG63 R&D #1 (Free 18 RWHP)
Old 08-02-2010, 09:39 PM
  #126
Racing Dad's Avatar
e63 2010 W212
Just made a post about this on another thread, but it seems like this is the one where it's at!
Sorry, not to dig up an old thread, but it just happened to me again! Shoot! I first did just the drop in K&N for 3 months, no problems. Took out the charcoal finally 3 weeks ago. CEL just came on this afternoon.
I'm still debating what caused it. Oddly enough I think the fuel has something to do with it.
I haven't quite worked out the logic, but would it make sense that a higher octane fuel would not allow the car to run less lean? I think that's the consensus on what the code is that's it throws.
I haven't thought it through yet. Higher octane isn't more horsepower, it just gives ability to compress more without detonation. But unfortunately here in CA, we only have 91 octane. Because it's 91, does the ECU automatically adjust for it altering timing and hence detonation and temp of engine? Which in turn potentially causes the engine to run lean?
Only reason why i say this is because for the past few weeks I usually do a mixture of 100 octane and 91 to get a blend somewhere in between 93. But i just filled up today a full tank without the 100 because it wasn't close by.
Huh... a conundrum. Any thoughts?
Old 08-02-2010, 10:19 PM
  #127
citylightva's Avatar
2007 E63, 2005 Dodge Ram Hemi
It's usually a lean code that it throws because it's getting more air. I have no idea how lean it actually thinks it is..? I had this problem, BUT mine was due to leaking intake gaskets, which I would seriously hope is not the problem on a brand new car.
Old 08-02-2010, 10:20 PM
  #128
And it's sure as hell not 18 at the wheels either...
Old 08-03-2010, 02:10 PM
  #129
MB_Forever's Avatar
E63 P30, CL500 Sport
It's a little interesting that some cars have removed the charcoals and put them back on so many times with no CEL what so ever while others experienced CEL right after charcoal removal or re-installation
Old 08-03-2010, 05:42 PM
  #130
benz_addict's Avatar
V12TT
Hey guys I noticed the black plastic part on top of the intake, top of the black x's, if we remove this part would we gain any HP?
Attached Thumbnails AMG63 R&D #1 (Free 18 RWHP)-air-boxe-no-charcoal-filter-web.bmp
Old 08-06-2010, 06:21 PM
  #131
Racing Dad's Avatar
e63 2010 W212
I noticed that piece as well. I didn't play around with it too much. I looked below at the air filter to see where it was dirtiest to get an idea of air flow. Which surprisingly seemed like more air flowed from the front, smaller section of the manifold / plenum. But I felt like if I removed it, air would flow evenly through the length of the filter causing extra wear on one part of the filter over other parts.
UPDATE on CEL and Octane: So, as mentioned earlier, my CEL came on 3 weeks after I took out the carbons, which was 3 months after I put in the K&N's. It was on for a week, all the time I was trying the ECU reset to no avail. I'm still under the impression it's not so much an ECU reset as it is a throttle reset (meaning it doesn't reset the ECU).
In any case, I filled up with 35% 100 Octane on the last fill up. And 20 miles into the tank, today my CEL just turned off on its own!
Has that ever happened to anyone? IMO seems like it's leaning towards the octane.
Old 08-06-2010, 09:56 PM
  #132
Registered User
DAGREEKNYC's Avatar
2019 s560 sedan
i had the cel kick on and off after removing the charcoals and installing the k&n filters . After a tune it never came back . how are u doing the ecu reset ? not that sneaky thing thats on some threads? thats crap dont work on 63s
Old 08-10-2010, 02:58 AM
  #133
Racing Dad's Avatar
e63 2010 W212
which tune did you get. ws thinking about it too. but didn't want to open a whole can of worms with one.
I was trying the reset where you turn it on, step on the peddle, turn it off, then release peddle. I've had other cars where it was a reset, albeit a little more complicated. But it didn't seem to do anything for me e63
Old 08-29-2010, 12:42 PM
  #134
evanswan's Avatar
2010 E350 SP / Honda Crosstour / prior vehicles - C32 modded / C300 modded / Lincoln LS modded
Air Box
Hey guys. I have the e350. Former Amg owner and I Know I'm in the wrong forum. But the regular guys don't do much in way of mods. And I'm noticing the E class non AMG owners talk about silly stuff.
Does the Charcole filter removal apply to the reg v8 and v6 engines on the 2010 and 2011's W212.
Also want to get up to at least 300hp from the stock 268hp. Any pulley's, exhaust, chips available.
Any good suggestions would be much appreciated.
Old 10-21-2010, 01:54 AM
  #135
Dericious's Avatar
CLS63
Just pulled my charcoal filters today. I think my car has been suffocating. seemed to be a bit more responsive to me hammering the gas. I wonder if charcoal filters get more restrictive over time. cause it sure seemed to be noticeable. don't know if it's actually faster, but definitely felt more responsive.
Old 10-22-2010, 10:40 AM
  #136
AlbertM's Avatar
E63 AMG 2010, Black, Pano, P2
It is strange. I had my charcoals removed, no CEL, then after several months installed K&N and airbox mod from TTM (cuts out the black plastic leading to the MAF) -- no CEL. So, I am not sure why some do and some don't.
Not sure about power gains, but felt more responsive.
Old 10-22-2010, 12:51 PM
  #137
bmontalban's Avatar
2007 E63
most likely they are not getting the boxes to seal up correctly, causing lean condition.
Old 10-22-2010, 05:44 PM
  #138
Tom_Boy's Avatar
2003 CL55
Kleemann has an E350 ECU flash that will get you way over 300 so I am told....
Old 01-03-2011, 09:12 PM
  #139
pkancel's Avatar
03 E500, 2010 E350, 2006 550i
How to get the airbox off
Should be easy but I dont want to break the clips. How do you remove the airboxes. The main cover that is connected to them, does that lift off completely or does the top come off and the airboxes stay connected to the engine somehow?
Old 01-04-2011, 12:57 PM
  #140
pkancel's Avatar
Anyone have some help on how to remove the airboxes or the engine cover to get to them?
Old 01-04-2011, 03:41 PM
  #141
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
See my DIY on the sparkplug change
Old 01-04-2011, 05:47 PM
  #142
pkancel's Avatar
Jon, thanks pal and I did look up your DIY Spark Plug change, which by the way will help me on my W211. But for the airboxes on either, especially on the W212, I cant see how to remove the engine cover that lays over the airboxes. That doesnt seem to be present in your DIY.
Old 01-04-2011, 07:41 PM
  #143
bmontalban's Avatar
2007 E63
the cover on my 211 63 just pops off, its clippled. start at the engines and pull up lightly till they pop loose.
Old 01-04-2011, 09:01 PM
  #144
pkancel's Avatar
No problem removing my W211, its my W212 where I am looking for direction?
Quick Reply: AMG63 R&D #1 (Free 18 RWHP)
