gas smell
Tell us, how do you fill your tank?
when you open the cap is there any pressure escaping?
Do you put the nozzle in as far as possible?
Full force with nozzle locked on max?
Half force with nozzle locked at half?
Almost full force with gas cap wedged/holding nozzle on?
Do you stop filling when the automatic shuts off, or continue to top off?
After you fill the tank dose the car run ok?
Do you ever see any liquid gas under car after refueling?
Part of the emission system includes a means to prevent gasoline from evaporating from the tank yet providing adequate ventilation. If the tank is over filled gasoline will back up in this system and contaminate and saturate the charcoal canister/filter that is vented to outside air and your engines induction system.
