verdict on cams
2 manycars the kleemann cams are built by schrick? what does your butt dyno tell you?
i read in one of the many threads last knight that the cams will take alil from the low end and add to the middle and top. if this is correct i will have to get them, wheel spin is a problem for me.
i'm expecting a bit reserved numbers since our weather here in arizona has jumped considerably since i had my pre install dyno run. oh well, what can you do...
i'm more interested in mph/et at the track anyways. vrus' tb only gave me 25ish hp on the dyno but was worth .3s off my et and +3mph. that's huge! if i can get that out of these cams i'll be doing table dances for half my ussual rates!!!
If I recall correctly, they are built by Schrick, but I will have to double check later. Butt dyno tells me low end and mid range are definitely improved. I will have hard numbers when the new parts are fully broken in.
I'm sorry to say I don't have any before and after dyno to post simply because I was never interested in what a stock car can do on a dyno. I will post what I get with my upgrades accordingly whp, wtq, and crank BHP/lb-ft using the 18% drivetrain loss percentage.
anyways, after a half dozen attempts we finally put some people in the trunk and got a better run. heat soak was apparent and spraying down the intercooler wasn't helping so peak gains at this time are quite conservative on the dyno dynamics machine. if we could have dyno'd under the same conditions as the pre cam run and not have wasted so many runs due to loss of traction, i'm sure results would have been better. i'll try to post the graphs when i get home but we were only able to get 8-10hp under these circumstances. regardless, everyone should understand that there ARE gains to be had and i would suspect 15-20hp through the entire mid range to top end on a dynojet. i'm not a firm believer in dyno numbers anyways. i'll let the track results speak for me. keep in mind what i said about vrus' tb. the conservative hp gains in no way represented how much improvement there really was...especially when the gains are spread throughout several thousand rpms instead of just peak improvements.
on a side note, the graph seems to be pointing out a new weak link. i'm in the middle of beta testing mufflers but put the oem mufflers on my custom exhaust since that's what i had for the pre cam dyno. even with all my custom exhaust work, because of the highly restrictive mufflers we seem to be losing a tiny bit on the top end. it looks as if the mufflers are good up until about 600 crank hp. after that they just can't flow. i'll keep you updated when we get a final muffler set up that works a little better.
adam, are your cams $2000 or less, same price as mb dealer slr cams?
thanks to chromikey for the info and help. keep up the good work and input.
Correct me if i am wrong..
Does it say 408 whp? If thats the case then how can it be 640hp at the crank?
And.. the gains with the slr cams...are they the same as the kleemann's or different?
Thx.
-K
How i wish cams were $2000 or less!!!
