Weekend Mods
I read Jangy's Pulley install instructions after looking at everything it seems straight forward. I ill make sure the pulley sits correctly on the key.
The Sensor arm instructions seem pretty straight forward too.
Any tips or tricks to be aware of?
FYI E554ME mentioned http://adjustableairride.com/ in one of his recent posts. I ordered the W211 kit in the evening the next day it was shipped. Excellent service!
More pics to come...
I will post more pics tomorrow with further review.
Before:
After:
Before:
After:
Before:
After:
Tools:
10mm Socket
Ratchet & long extension
2 10 mm wrenches
2 flat head screw drivers (longer in size)
Curved long Needles nose pliars
Grabber Tool
Digital Caliper
Silicone spray
Floor jack or lift
http://www.harborfreight.com/cpi/cta...emnumber=47257
http://www.harborfreight.com/cpi/cta...emnumber=94162
Tools:
Breaker Bar
27MM Socket short, deep
8mm,10mm & 13mm Socket
½, 3/8, & ¼ Ratchet & Extensions
2 Large flat head screw drivers
1 Small flat head screw driver
Needle nose pliers
15 Torx on a socket
17mm closed box Wrench
200+ Lb Torque Wrench
13mm Bolt 3” or so in length
Grease
Coolant
Floor Jack, Jack stands or lift
Bottom:
- Jack up the front end or lift the car
- remove three front belly pans under the car (8mm socket on ratchet)
- Remove the 15 torx screws that hold the hose brackets to the fan housing
- remove the black plastic dust cover on torque converter (Near the center on the front of the tranny in)
Top:
- Pop the front engine vanity cover off the clips a little yank and they pop out
- Remove the front belt by using a 17mm wrench to move the belt tensioner
- Remove the plastic crush pins that secure the black rubber gasket that runs front to back.
- Remove round plastic pins size of 1/2 dollar and the plastic rectangular piece under the plastic pin
- remove the six 10 mm bolts (3 left & 3 right) this secures the metal bracket that goes over the radiator
- remove the 2 10mm bolt that secures the bracket from the bottom
- set bracket forward out of the way revealing the radiator and fan
- pop 2 fan clips out with screw driver
- detach fan wiring harness
*optional step
- pull top radiator hose pin out with needle nose pliers. Place catch pan under the hose pull hose some coolant will pop out. If you have two people you can pull hose while pulling the fan up and out and then put the hose back in for minimal coolant loss. If you skip this step getting the fan out is not that big of a deal but getting the fan back in is difficult as the fan catches on the hoses.
-Pull fan completely out of the car
Bottom:
- using 17mm Socket on ratchet pull the lower tensioner to remove the rear belt. I did not remove the rear belt completely I just took it off one pulley.
- In the torque converter you will see 13mm bolts (You may need to spin the pulley with a 27mm socket and ratchet/breaker bar to reveal one of many 13 mm bolts) Remove one bolt. You will need another 13mm bolt with the same thread pitch I would say 3" is good. Thread the long bolt in enough to get a good grab. Maybe 6 turns. when you turn the pulley it will lock the pulley in order to give you the ability to remove the pulley bolt.
Top
- Now your ready to remove the pulley nut. Using a larger breaker bar and 27mm socket (deep may be required or socket and small extension) Remove the pulley bolt. It is a normal thread so lefty loosely rightly tightly. Once you break it loose use a 1/2 ratchet to remove the bolt.
- The pulley takes some wiggling and pressure to get it to move. We had one person on the bottom and one on top using flat headed screw drivers to apply pressure outwards while taping with a rubber mallet.
- bring the pulley up through the top
- new pulley mark where the key groove is with nail polish or similar paint. line the groove up with the key on the shaft. Again have someone on the bottom holding the pulley while the top person positions the pulley and aligns the key. Some of this is going to be "feel" though the pulley. We also used some grease to make the pulley slide on easier.
-When they pulley is set on the key start threading the large bolt the pulley should start moving back in to place. 200Lb of Torque needs to be applied. My TQ wrench only went up to 150 so it gave me a chance to pick up a bigger wrench
$120 at sears for 1/2 Craftsman.Top & Bottom
- Go in reverse and put everything back together. **** DON'T FORGET TO REPLACE THE 13mm BOLT IN THE TORQUE CONVERTER BEFORE STARTING THE ENGINE****
