Looking for Johnson pump.
Old May 25, 2007 | 04:47 PM
Jrocket's Avatar
E55
Anybody have a new or used pump in perfect condition they want to sell?
Old May 25, 2007 | 05:03 PM
jason427's Avatar
Viper/Z06/E55/GT500
Are they hard to find new? I probably need to address this since Im considering a pulley swap.
Thanks,
Jason
Put me in line second.
Old May 25, 2007 | 05:09 PM
sang55's Avatar
K3 05 E55 sold, 09 GL550
I had 1 brand new model 2008 CM 90 for sale .
BiTurboAmg's Avatar
SL65 AMG
pm e55 killer i know he has one he was going to sell.
Old May 25, 2007 | 05:50 PM
sang55's Avatar
If you lived in SD , call Marine at 619 222-0334 that is where I got mine . But you have to wait about 4 to 6 weeks because they're back order . if you want right away I had one for sale for $310
Old May 25, 2007 | 05:55 PM
MiKeSSw203's Avatar
From: South Coast Metro/Cerritos/Yorba Linda California
'05 C230K '10 GLK350 '13 SMART
Old May 25, 2007 | 05:56 PM
Jrocket's Avatar
E55
Thanks,
Jason
Ive tried the 2 larger suppliers that I know of and they are back ordered.Looks like 265.00 shipped for the pump is the going rate so far.Hopefully they will be in shortly.
Old May 25, 2007 | 06:02 PM
01bolt's Avatar
01 lightning,05e55amg
johnson pump
i have a new pump just got them in pm me
Old May 25, 2007 | 07:44 PM
sgtstanko's Avatar
2006 E55
I found three CO90 here in Orange County.......$313.00
http://www.johnson-pump.com/JPmarine...ion/index.html
Old May 25, 2007 | 08:01 PM
Jrocket's Avatar
E55
What store?
Old May 25, 2007 | 09:05 PM
psk145's Avatar
2006 E55
is there going to be an install day somewhere???? If so, I'll look into one also
Old May 25, 2007 | 11:02 PM
BenzoBoi's Avatar
Super Moderator
W221
Is this sort of like the cooling upgrade in a way?
Old May 25, 2007 | 11:20 PM
Jrocket's Avatar
E55
Its the IC pump that replaces the stock unit.
Old May 25, 2007 | 11:24 PM
BenzoBoi's Avatar
Super Moderator
W221
Thank you fer the heads up bud...
Is there anything else besides the pump itself that we need to get...ie. hoses or anything of that nature?
Old May 25, 2007 | 11:30 PM
Jrocket's Avatar
E55
Evosport,Kleemann and renntech all have cooling kits that have this pump along with other parts involved too make a cooling kit.
Evosport is the most used and common kit,I believe.
Old May 25, 2007 | 11:42 PM
BenzoBoi's Avatar
Super Moderator
W221
Thanks again bud...
Old May 26, 2007 | 02:12 AM
sang55's Avatar
Guys, you got to run the Johnson pump with 30amp heavy duty relay .
BTW the C090 is the older model , The newer one is CM90 high flow rate .
Old May 26, 2007 | 09:14 AM
Jspeed's Avatar
E63 biturbo
Can the CM90 fit? I was told it was bigger than the CO90. If so I'm going for one myself.
Old May 26, 2007 | 03:23 PM
sang55's Avatar
They're both had the same size . I have them both ,they 're all have 38mm inlet and outlet but the CM90 maybe have a bit heavier .
Old May 28, 2007 | 08:55 AM
E55 RUSS's Avatar
E55K
I want one as well...Which one ands where is the best place to get one ???
Old May 28, 2007 | 11:45 AM
jangy's Avatar
2015 S212
I've always used Marine in San Diego. Maybe we can get a group buy from them?
Is everyone planning on wiring it to stay on whenever the car is on, or are you all planning on going with OEM switching? I'm wiring it to stay live. 5000 hours is plenty for me.
Second, is anyone going to attempt to make like the big tuners and separate the engine cooling from the SC? I'd be interested in that project as well.
Old May 28, 2007 | 11:59 AM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
Originally Posted by MiKeSSw203
I'm glad I'm not the only who thought that when I read it
Old Jun 10, 2007 | 02:50 PM
mbenzman's Avatar
All of them!
Where are you guys getting the hose adapters for the Johnson pump? I see a lot of talk about where to source the pump, but without the adapters for the smaller diameter factory hoses, good luck installing them!
I've installed the kits, but of course they had the adapters included.
