Factory AMG Wheel Question - Help
Old Jun 14, 2007 | 09:17 PM
Torquey55's Avatar
2006 E55
Are E63 factory wheels the same size as E55 factory wheels? Would my aftermarket wheels from my E55 work on a E63? I think they are the same but I need to know 100%.
Old Jun 14, 2007 | 09:26 PM
Jrocket's Avatar
E55
E63 fronts are 8.5 wide,E55 fronts are 8.0 wide.Other than that they should have the same offsets? Jay55 has E63 wheels on his car and its lowered.
Old Jun 14, 2007 | 09:40 PM
Torquey55's Avatar
2006 E55
I want to know if my E55 19x9 with 255/35 and 19x10 with 285/30 will fit on a E63. I am selling them and an E63 owner wants to know if they will work for him. Thanks for any replies.
Old Jun 14, 2007 | 09:42 PM
Jrocket's Avatar
E55
I dont see why they would'nt.
Old Jun 14, 2007 | 09:43 PM
Torquey55's Avatar
2006 E55
I was kinda thinking the same thing, but I had to ask you guys to be 100% sure. I can't trust my own judgement any more.
Old Jun 14, 2007 | 09:47 PM
Jrocket's Avatar
E55
Some have put e63 stock wheels on the E55's,and they are wider in the fronts.So I would assume your wheels should fit the e63 without any problems.Same body and dimensions as far as I know.
Old Jun 14, 2007 | 10:47 PM
Torquey55's Avatar
2006 E55
I was hoping to hear from the jangster. He knows for sure.
Old Jun 15, 2007 | 01:05 AM
jangy's Avatar
2015 S212
I'm here!! Yes, a setup on the E55 will be fine on an E63. The E63 fronts are indeed 8.5s, but that is simply a change in the wheels and not in the axles.
The CCWs would be HOT on an E63. I would suggest a very small spacer, so that 295s can be run in the rear. Also, I would bump the front to 265s.
Other than that, the setup is straight bolt and play!!
