CLS55 Kleemann or ECU?
Old Jun 17, 2007 | 06:40 PM
maximus193's Avatar
Hi Guys first post for this newbie.
I'm considering going for the Kleemann Stage2 package with LSD. Should run for about $10K.
OR
I could go for a company that does ECU remapping for $1K but produces 548hp.
So the numbers are about the same, but the costs isn't. The ECU is very reputable in Europe (where I live).
Would splashing the extra $9K for Kleemann make such a huge difference?
Old Jun 17, 2007 | 06:52 PM
Jrocket's Avatar
E55
79hp out of an ecu tune,I'd like to see that.Who does this tune?
Old Jun 17, 2007 | 06:59 PM
maximus193's Avatar
European company called http://www.digitune.nl/2006mbcls55amg476.htm
But there are several reputable European companies who claim to get anywhere from 45-75hp gain just by an ECU remap.
Old Jun 17, 2007 | 08:26 PM
paul928's Avatar
04 E 500 4matic wagon; CLS 63 AMG
OR
What might be worth the cost is the LSD and a supercharger pulley, and these can be obtained from a number of sources.
Old Jun 17, 2007 | 08:42 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
not going to happen on a 55 with only an ecu tune...no way, now how.
Old Jun 17, 2007 | 09:38 PM
JamE55's Avatar
Out Of Control!
You're being punk'ed. Don't fall for it.
Old Jun 17, 2007 | 10:34 PM
BenzoBoi's Avatar
Super Moderator
W221
Very liberal numbers for just an ecu tune...
Old Jun 17, 2007 | 11:34 PM
Tuskir's Avatar
Common sense should tell you that the only way to get 80hp from CLS55 is by either increasing boost via aftermarket pulley, or drastically improving air flow with headers, exhaust system, larger TB, etc.
You don't really need an LSD, just go for kleemann stage 1 (pulley + ecu), its only around 3,000$ if I remember correctly. Then if you're not happy with the power, you can add headers.
Old Jun 18, 2007 | 05:31 AM
maximus193's Avatar
Yes, common sense makes me question this ECU "update".
However, there are loads of European reputable companies that claim the same increases. However, they all do not include the pully. So perhaps that's the bottleneck?
Let me also refraise my question. Is the increase in power from Stage 1 to Stage 4 worth all the extra cash? Is it really noticable?
Old Jun 18, 2007 | 06:48 AM
Efivefive's Avatar
E55 AMG
An ecu tune alone is worthless.......The only main advantage would be a crisper throttle response, max HP to be gained is probably 20hp...if that????
.....European tuners like digitec and dms make some wild claims...but that's all they are....wild.
Stage 2 is probably the best package to get, which would be ECU, Pulley and Headers.
Old Jun 18, 2007 | 07:06 AM
maximus193's Avatar
Exactly the kind of reply I was waiting (hoping) for!
There are indeed a lot of these chiptune companies making the boldest of claims. I would expect something else from a reputable tuner like Kleemann.
I'm still deciding between Stage 2 or 3 with the extra LSD and/or camshaft.
Old Jun 18, 2007 | 01:30 PM
ROCKETW19's Avatar
06 EuroElites E55
i like the LSD but i dont know about the cams. no one and i mean no one has added cams and posted a dyno. that seems funny to me, i dont belive they are worth it. ask kleemann to show you a cam only upgrade dyno sheet. now the throttle body is a upgrade i realy liked.
Old Jun 18, 2007 | 02:10 PM
maximus193's Avatar
That's the beauty of Kleemann. They let you customize your own tuning as you can combine various Stages.
Old Jun 18, 2007 | 02:12 PM
ROCKETW19's Avatar
06 EuroElites E55
not sure what you mean by that but all tuners work just like kleemann. they are not special.
Old Jun 18, 2007 | 02:16 PM
maximus193's Avatar
I meant that you can do Stage 2 tuning and include the throttle body from Stage 4.
Old Jun 18, 2007 | 02:36 PM
chiromikey's Avatar
i don't know about the kleemann cams but two members here have posted dynos for slr cams.
Old Jun 18, 2007 | 03:15 PM
ROCKETW19's Avatar
06 EuroElites E55
were they only cams? or did they do other upgrades also? i will search right now but ill tell you the search function sucks. if you have a link that would be great.
Old Jun 18, 2007 | 03:47 PM
ROCKETW19's Avatar
06 EuroElites E55
i searched and came up with a bunh of BS no cam only dynos. please help. especialy if it helps mid to top end my car realy suffers there.
Old Jun 18, 2007 | 04:03 PM
E320kieser's Avatar
E320 W211
ECU is more worth it IMO
Old Jun 18, 2007 | 05:45 PM
chiromikey's Avatar
I don't know the post title but you can search my post history for cam only dyno results. i'll look later if you can't find it. sorry i don't remember the other member that posted dyno results but i KNOW they're here somewhere.
