E63 LSD for an E55?
Old Jul 3, 2007 | 10:59 AM
fauvre's Avatar
'05 E55, '07 ML500, '86 Porsche 951 track car, '09 997 C2S, '08 S63
E63 LSD for an E55?
I am going to put a limited slip differential in my car - after a track day it becomes quite clear that it is necessary for these cars. I can do an aftermarket install, like Kleeman, but would prefer to use AMG's. Has anyone done this in the US? I know the AMG factory will do it in Germany.
Also, any positive or negative experiences with the tuner LSDs?
Old Jul 3, 2007 | 11:02 AM
V12Godspeed's Avatar
Your worst nightmare...
I was just asking myself the same question the other day, will an E63 LSD fit in an E55???....Hmmm....that is a very good question, lol!
Old Jul 3, 2007 | 11:33 AM
CynCarvin32's Avatar
Mercedes Benz
Both the AMG and Kleemann LSD are very conservative and offer limited locking ability. If you really want a top end diff for track driving a quaife is the the only real option. It offers 100% locking as long as both rear wheels have contact with the ground.
It will transform the car at the track. The kleemann diff really was designed for drag racing reasons and a quaife is designed to be best on a road course.
Old Jul 3, 2007 | 01:02 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
The only LSD to fit is a Quaife ... forget the rest.
Old Jul 3, 2007 | 08:23 PM
Vadim @ FD's Avatar
S600TT, R350
Fauvre: Here are your options on the diffs:
1. AMG - Factory Salsbury style differential. Somewhat pricey ~$5K and hard to get.
2. Kleemann - more like a modification to a stock unit that adds spring plate to spider gears. Fairly easy to install, but not a true diff.
3. Quaife - Torsen style differential. Works very well on 55/32s. Easy availability and the best price. ~$2K installed.
4. BRABUS, RennTech, Carlsson - mostly resellers of AMG diff with added mark-up. One quote for one of my old customers was over $9K, plus install.
Old Jul 4, 2007 | 03:14 PM
fauvre's Avatar
Sounds like it's a Quaife... Any issues with factory traction control settings and the Quaife?
Old Sep 3, 2007 | 01:48 AM
defeasible's Avatar
2007 AMG E63
Fauvre - let us know what you have found out. Another E63 owner here about to do the same, but I am definitely a bit concerned about goign anything other than the crummy 40% LSD offered by AMG for the effect on the control unit and programming. Very curious if anyone can confirm success with Quaife.
Old Sep 3, 2007 | 01:51 AM
Jrocket's Avatar
E55
The LSD's are mechanical devices,no electronics are involved in either the factory AMG or the Quaife.Only time you'll need anything tuning wise(electronics)will be if you change the gear ratios.
Old Sep 3, 2007 | 05:38 AM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
if i recall there was a debate that MBuse stated that the AMG ls suited the amg cars and that other lsd could cause damage. do not recall what came of this debate though
p.s thanks for the info vadim
Old Sep 3, 2007 | 08:38 AM
rflow306's Avatar
2005 E 55
I agree the Quaife is the way to go here is their website http://www.autotech.com/quaife/index2.htm
Old Sep 3, 2007 | 09:48 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Quaife hands down. Great unit! Had some reports of just plug n play, no shimming required.
Old Sep 3, 2007 | 11:17 AM
jangy's Avatar
2015 S212
Many here have Quaifes on their cars with no issues. I do not know about the E63.
The AMG LSDs are a bit od. The one for the E55 is a 30% locking and the E63 on eis a 40% locking. I have not tried anything, but was told that the E63 one will NOT work on the E55 and that is why they decided to offer both models. The cost is the same for both.
I'll be quaifing soon.
Old Sep 3, 2007 | 01:52 PM
juicee63's Avatar
2011 twin turboed prius
Can you explain what the % lockup ratings mean in real world track experience?
30% vs40% vs 100%? Does this refer to wheel slippage?
Thanks Jangster
Old Sep 3, 2007 | 02:08 PM
jangy's Avatar
2015 S212
Thanks Jangster
Basically, there are two styles. There are the ones that have an "on - off" type engagement and those that do the gradual (quaife).
In the case of the AMG ones, the 30% and 40% lock up refer to the "on - off" setup. So, as slippage is noted, the diff puts a 40% lock on both wheels and the rest of the power is distributed as with a standard diff. For the E55s, we would only get a 30% lock, which is still noted, but not maximal when you have this much power.
The quaife, on the other hand, is variable all the way from 0% to 100%. It is a mechanical system (as is the AMG one), but it just continues to add lock up as it gets more slippage. That is why this setup is considered ideal over the other.
It is much smoother, as it can transition better and it ultimately even has a stronger lock. They also have an excellent name and reputation.
Old Sep 4, 2007 | 01:44 PM
Vadim @ FD's Avatar
S600TT, R350
Mr. Fauvre went with Quaife. We installed several months ago and it is running great.
Highly recommend it.
