New Wheels/Issue(s)-Question
'11/E63-Former car: '05 RT4 E55, Sprintbooster, Phenolic Spacers, RT IC /Secondary HE & BMC Filters
Just put on new wheels (19's) and treads (275/35 & 245/30). All looks good, but noticed on road/fwy steep dips and once on hard turn there seemd to be a scraping sound. Went to MB dealer today and service guy put 55 on rack and mentioned there was slight scrape marks (black tire rubber) on inside part fender where it faces flush to treads-assume outer part of larger tread edge is what touched; the inside of wheel well looked ok. This doesn't happen all the time, but here and there given road elements. Has anyone else that swapped to 19's experience this? Can anything thing be done to totally mitigate, or a part trade off for running larger wheels/treads? Any issues with this? Will try to post pic's soon. Did tread/tire combo at Tire Rack for Weds Bavaria II's & B'Stone reo5oa's 's. Thanks all.
2003 E55
Agree, this is an off set issue. Check the wheels and post the numbers. You can't fix this. Either you need new wheels or try raising the car (if lowered). Sorry.
Weds Bavaria II's:
Front-
Offset: +32mm
Bolt Pattern: 5-112
Rec. Tire Size:245/35-19
**Lightweight: 25.5lbs.*
Rear-
Rear Fitment: 19x9
Offset: +30mm
Bolt Pattern: 5-112
Rec. Tire Size:265/30-19
**Lightweight: 27.5lbs.**
no lowering module. 55 is standard. this happend sport/1/2 and city ride option/s. not sure what is happening??? only happend where some big dips on 101 north here in Marin. assume this should not be happening at all and not okay (or should not live with) if even once in awhile?
I don't think you specified which was rubbing (front or rear), but with only a +30 offset I believe that is your problem. you need 35-40.
K3 05 E55 sold, 09 GL550
I had same issue like your before when I had Yoko Advan on my 19'' . actually they may sent you the bad tires you should talk to tire rack or bring them to any shop tires to do road force machine . Dont talk to MB tech they dont know anything about low profile tire . BTW i'm running 19x8 F and 19x10 R with 245/35 & 285/30 with no problem at all . Hope this will help
