Wife destroyed rear wheel
Wife calls to tell me that she just heard a loud pop and looked into the mirror to see all of the air shoot out of the rear tire. I get there and find that she ran over a large allen wrench that put about a 1/4 - 3/8" hole in both the tire and rim. Didn't find the hole in the rim until I had taken the time to put a plug in the tire and it still wouldn't hold any air.
I figure that now is probably a prime time to upgrade to wider rear rims and 295's. If I remember correctly, the AMG Style IV 18" from the SL550 are 9.5 inches wide and the correct wheels for 295's. Is this correct, and if so, where is the most reasonable place to get them from that can get them here in a few days? Thanks as always.
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Looks like no arguement from the little lady over new rims
BTW amdeutsch wants his allen wrench back.
My wife has done the same thing to our cars. I use to think that she was just a bad driver............................. but the Internet has taught me different.
AMG Rider, I'm not sure if that's something that can be repaired, but since she feels bad and won't give me hell for spending $$$ on wider replacements, its not something that I'm even going to look into.
Rock, she's referred to the beast as "The Mistress" before, so you might be onto something. I tried to tell her that the boat really is my mistress and the E is just some meaningless side action, but she won't buy it.
2004 SL500R / 2003 BMW M5
VERY VERY expensive on the second count. Both may give you immediate satisfaction both the second option may/will stay with you for years to come and will have severe monetary consequences! Just get the rim and pay once, not every month.
There are some things in life that you need to try once before you die. I can assure you without hesitation that there will NEVER, NEVER be a new wife. If this one is ever gone, the job will then be outsourced through various temp agencies, but never again a permanent replacement.
So does anyone have any good leads on reasonably priced OEM replacements.
If you want to stay with the AMG Style IV look, then yes 9.5 is the best bet.
A few months back when I did mine, closest fit was from the '07 SL550. It is an 18X9.5et33. I took them to my machine shop and had 4mm shaved off the face of each, making them a final et of 37. Then, popped on 295s and have been raging ever since.
In the mean-time, I saw some AMG Style IV 18X9.5et40. This would be IDEAL, but I'm not sure on where to get it.
I'll do some digging and post here if I find it. Also, ask away if you have any questions on the SL rims.
Now that's some funny ****. I saw a few of your future posts without all the caps. Did you find it easier to type, or is the other way too much of a habit?
BTW, she was on the phone with her girlfriend and didn't see the 6" allen wrench lying in the road. Not certain that I'd have seen it either, but I would like to think so.
Thanks Jangy, I was trying to remember where you had discussed this before and came up empty with my searches. What is a reasonable amount to pay for the 18 x 9.5 wheels? I found a few places online for as low as $350 +/- per wheel, but not sure if they are inferior knockoffs or the real thing.
Make sure to get the real deal. I paid $550 each for them (delivered), $75 each to machine, and $80 each to powdercoat.
Tire rack does carry OEM rims, but they did not have any off of the '07 models at the time. They may now.
I know it can be repaired, and i even suggest doing so. But, that is only so he can run the 9" ones in the front and put the SL rims in the rear!!
[QUOTE=Hazy1;2325150]Wife calls to tell me that she just heard a loud pop and looked into the mirror to see all of the air shoot out of the rear tire. I get there and find that she ran over a large allen wrench that put about a 1/4 - 3/8" hole in both the tire and rim. Didn't find the hole in the rim until I had taken the time to put a plug in the tire and it still wouldn't hold any air.
[QUOTE]
damn!!
maybe it's time to trade her in and get a new younger one... the car i mean.
[QUOTE]
damn!!
im not sure, but i dont think i can see my rears even if i angle the mirrors all the way down...
edit: Jangy: you dont get the 295 wiggle on the SL550 rims machined to et 37?
I'm sure it has been debated here before, but why would a 295 wiggle and a 285 not? There are two basic differences: size and contact patch. So, does added traction cause the wiggle? I say no, because running 275/35 DRs on the rear gives me GREAT traction and I only get the diff wiggle. Then, there is the size. If the arms are flexing, which I think they do, then you may be rubbing. I've seen signs of that internal rubbing on other cars, but not mine. I try to set the car up with the thought that it will toe in just a bit under load.
The only cure I know of is to make stiffer arms under the car. Obviously, that wil help translate even more power to the ground and at some point, we would find the next weak link, which I suspect may be the diff.
