Little convenience questions re: E63
Now that I'm using full throttle and feeling the earth shudder under that mountain of torque, I have a few questions about conveniences. First, is there a setting where the right rearview mirror dips down to give you a view of the curb when you put the car in reverse? I had that in my C32. I have the side mirrors set up with the control on the right so it's not that. Also, is there 1-touch closing of the panoramic moonroof? It doesn't do that on mine.
Otherwise, perfect...
You can have the dealer program your car to have the passenger mirror tilt when in reverse. I know this is possible as Sunil from Motorwerks programmed mine when installing my power folding mirrors.
Can't believe this car wouldn't have this as I became addicted to this feature with my earlier CLK55.
No convenience option in my version
I checked the manual, but my version of the car apparently doesn't have the tilt mirror down option available from my convenience menu. Sigh.
On the other hand, found the afterburners. The car goes from really fast to really, really fast above 5500rpm. I swear I felt another kick to the seat, as if that were possible, as the car cleared 6000rpm in 2nd gear. Always good to get my heart rate to match the engine oil temperature at full throttle...
