is it ok to cut through the metal under the rear shelf?
Old Jul 27, 2007 | 10:30 AM
narf's Avatar
W211 E55 AMG
I want to mount a new sub (jl 10w7) in place of the stock one. As they are both 10" units, it shouldn't be too difficult (how hard can it be? famous last words).
My problem is that the new sub would have a significantly lower mounting depth, and i would need to cut away some of this metal brace under my rear shelf in my trunk.
Does anyone know what its for? It is a problem to remove, or should i just cut a hole through it?
I dont want to compromise structural rigidity in my car for better sound...
thanks//Richard
edit: i originally posted a similar question in the audio& electronics board here but decided to ask here as you guys here will be more familiar with the w211 e55 than anyone else...
Old Jul 27, 2007 | 10:59 AM
leonenglewood's Avatar
E63 amg 2007
i think u need to have a inclosed box for the w7
Old Jul 27, 2007 | 01:13 PM
narf's Avatar
W211 E55 AMG
i intend to mount a sealed enclosure directly below the sub, mounted to to rear shelf, provided i can cut through the metal brace and not ruin my car
Old Jul 28, 2007 | 12:52 AM
emax's Avatar
2004 E55
It would not be a problem. Back in the Day I ported 3 holes through the deck lid on my Volvo and it sounded sweet!
Old Jul 28, 2007 | 12:56 AM
narf's Avatar
W211 E55 AMG
its not just the deck lid though, its the metal brace that runs across the car under the deck lid, in the trunk...
im trying to figure out what purpose it serves...
Old Jul 28, 2007 | 01:00 AM
emax's Avatar
2004 E55
Ohh, well it probably makes the car more rigid, taking it off may make the car a little less solid. If this is the case you could likely weld a rod under the car to make up for it. My idea for a system is to put one 12 in the spare tire well inclosed with a flush fiber glass box.
Old Jul 28, 2007 | 04:28 AM
Rafal's Avatar
2017 S63 Coupe Iridium Silver
It's a roll cage for your track days....
Old Jul 28, 2007 | 07:20 AM
E63 amg 2007
theres no prob. u can cut that off
Old Jul 28, 2007 | 08:27 AM
machz990's Avatar
2005 E55 Black
If it didn't serve a purpose MB wouldn't have put it there. I would do more research before cutting up the car.
Old Jul 28, 2007 | 01:25 PM
jangy's Avatar
2015 S212
I've seen it done with no issues. You will need to cut a hole for the magnet to fit through. There are no issues with true integrity. Worst case is that you weaken the rigid shelf and it starts to rattle. Keep the cutting to a minimum and you will be fine. Again, I've seen it done on at least 3 W211s.
Old Jul 29, 2007 | 12:57 PM
narf's Avatar
W211 E55 AMG
thats why i am asking...
Im sure it serves as a roll cage as much as my panoramic sunroof does...
thank you everyone for your responses, i guess ill just keep the cutting to a minimum and hope for the best..
What i really wanted to do was either remove the whole thing, or cut away a significant section from the middle, and mount the enclosure closer to the rear shelf. I think i've got like 10cm of space between the metal brace and the rear shelf... Maybe its better to just put the sub somewhere else...
//Richard.
