Changing trandmission fluid.....how to
Old Aug 1, 2007 | 05:09 PM
StevesAMG's Avatar
03' E55, 06' Kawasaki ZX-10R
Hi all,
I have read a few threads in which some other members had their transmission fluids changed and it improved their cars shifting etc.
I have a higher mileage 03' that is no longer on warranty and was looking to do it myself.
Does anyone know how hard this is to do?
If it is something I shouldn't do myself...will one of jiffy Lube type places be able to do it for cheap or is that a bad idea.
Thanks for any input.
Old Aug 1, 2007 | 08:19 PM
StevesAMG's Avatar
help me out.....
Old Aug 1, 2007 | 08:30 PM
SUNILP's Avatar
2015 E250D
First, using a 5mm HEX socket, pull the drain off the tranny pan. If you do not have the factory measuring tool, then make sure you collect all the old fluid and measure it so you know how much to put back in the tranny.
If you are pulling the pan off, do that next. Get a new filter and pan gasket.
The fill tube is on top of the engine bay, Usually has a black cap with a red or black lock on top that prevents people opening it. You will have to pull the lock off the cap with a flat screwdriver first and the cap will come off afterwards.
Fill in exactly the same amount of tranny fluid you took out. Make sure you use OEM fluid from the dealer. Atleast I always recommend it.
