e63 brake squeal
Received 4,435 Likes
'71 Pinto
![Arrow](https://mbworld.org/forums/images/icons/icon2.gif)
211.077
MBUSA DTB P-B-42.10/76 JUL07
If rear brake squeal occurs your current pads will be replaced with revised pads part number A005 420 22 20 under warranty with no mileage limit.
2015 BMW 640ix GC (Ruby Black)
Now, do I want to shlep out to NJ to get this done or wait for my 1-year service? Choices, Choices. Thanks much for the post.
=NLK=
'71 Pinto
Thanks for this note! Do you know if this is just for 2007's?
I have a 2006 E55 and the brakes squeak really bad sometimes.
Thanks!
TK
Thanks!
TK
'71 Pinto
06 SL600
2007 MB E63, 2006 LEXUS GS430
any one having problems with getting this fixed under warranty? At my 3000 mile check up, i told the service advisor about the brake squeal and then at the end they said: We had the brakes checked and they are perfectly normal, this is how high performance brakes sound
'71 Pinto
'71 Pinto
Front brake pads part # A004 420 89 20
Rear brake pads A005 420 22 20
Retaining spring, front caliber A001 421 09 91
Pin kit, spring to front caliber A000 421 51 74
My God, it's about time MB finally admitted that brake squeal of this level is not normal. You guys cannot imagine the ***** I had to go through with MB to replace my rotors and pads in order to stop the school bus squeal. On my 04 500 coupe they had to replace one side of the fronts twice within a week as the new rotor was out of spec which caused a slight vibration and the squeal. I recently had the squeal with my 07 997S and Porsche stepped up to the plate and replaced my rotors and pads but they are very reluctant to do it and also like to say it's normal. Unfortunately, with all the cost cutting going on these days the quality control has suffered in many areas.
08 SL55, 07 E63, 07 S550
As of 12/19/07 this DTB has been revised to correct both front and rear brake squeal with revised pads:
Thanks for the helpful info.
1 Post
2010 E63, 2008 Range Rover Sport, 2010 GLK350
P-42_46-32B NOV 04 Brakes - Whistling Noise When Pressing Brake Pedal
P-42_46-43 JUN 04 Brakes - Squeaking Noise On Application
I have a 2005 and will bring mine in also as it just started to squeak slighly and its a CPO car i just got a short time ago!
07-E63, 07 911 C4S
Give me a brake
![bs](https://mbworld.org/forums/images/smilies/bs.gif)
'71 Pinto
'08 E63, '08 ML350
I picked up my 07 E63 from the dealer a few weeks ago and brakes started to squeak (on lite application), called the SA Manager and they gave me the standard line - high performance brakes squeak. Then I found this thread and forwarded it to him, he said the parts and memo related to US cars only
, does anyone know if he is feeding me another line? FYI, I am in Canada and I bought the car from a Canadian dealer. He said he did speak with shop foreman who has a few ideas from MB Canada on how to deal with the issue. Car is going in tomorrow, I will wait and see.
Had the front and rear pads replaced per the DTB during the E's initial service. Everything has been perfect for the last 500 miles...hope it stays this way.
07-E63, 07 911 C4S
07-E63, 07 911 C4S
Brakes Update
Finally had my car in for servicing. I was advised that my front brakes had the new pads in, but the back did not. Had the car for a few days, no noise yet, I will keep everyone updated.
i had my brakes swapped out back in september 07 as a courtesy. however, im reading on this post that the DTB info got revised in december 2007? Does that mean i am qualified to get my brakes replaced? im tired of this annoying squeal that did not get fixed from my first swap out. not to mention the run around i get from each dealer that says AMG brakes are meant to squeal...
2007 E63 AMG
My 2007 E63 has 20,000 miles on it. It has brake squeal noise since I got it, would they still able to replace the rotor and brake pads?
