Forgeline SP3P 20x10's rear offset question?
05' Blk E55, 04' G35 Coupe 6 spd
Has anyone fitted 20x10" rims on their E55's in the rear without rubbing the outter/inner fender wall? I'm planning on getting Forgeline SP3P rims. I'm also planning on lowering the car with the Renntech ELM to remove the wheel gap, but not slam the car. This question has probably been beaten to death but I can't seem to find the answer. I would like to go with 285/25/20 sized tires for the rear with a 37 offset. Does anybody know if that will work or should I go 38 to 40 offset to prevent rubbing? I don't want to modify the fender wall if not necessary. Any help would be much appreciated. Thanks.
