Where is the i/c pump? Need to replace...
Old Aug 22, 2007 | 11:52 AM
userID's Avatar
03 E55
Hi all, I just purchased a johnson cm30 pump and wanted to do the install myself. I chose this one b/c it seems everyone says that its the easiest for direct replacement. Anywho I have no idea where the pump is at. What is the easiest way to get to it? What to remove? I did searches in threads and they showed pictures but I could not make out where on the car it was at.
Thanks in advance guys for the help!
-Van-
Old Aug 22, 2007 | 11:59 AM
SteveFox's Avatar
Bentley Flying Spur, CL550
-Van-
I'm not intending to be rude or anything but I put two very informative links in the other thread you started about the pump. It says clearly the pump is behind the front passenger wheel. There's pics too.
Old Aug 22, 2007 | 01:55 PM
Jrocket's Avatar
E55
Not too be rude here,but if its this hard for you already,I suggest you have a qualified shop do it for you.
Old Aug 22, 2007 | 03:50 PM
userID's Avatar
03 E55
It does help thank you. On the two links you sent me I dunno why but my eyes only went to the second link where there was just pics. Sorry to bother yall.
Old Aug 22, 2007 | 07:57 PM
StevesAMG's Avatar
03' E55, 06' Kawasaki ZX-10R
If no one else will help you I will.
It is located on the front of the passenger side ofthe car right next to the radiator....
It is very easy to access. Put the car up on ramps or even jack it up and secure it. there is a large black plastic piece that covers the bottom front of the car. You will need to remove the screws holding this up(you can leave the ones on the driver side on as it will drop enough for you to get to the pump.)
Once it is down, you will see the pump, it is the size of a soda can(bigger than your CM30) and has two hoses and one small wiring harness. the hoses will bolt directly up to the CM30, to install the wires, just crimp or cut the stock and attach the red to red and brown to black on the CM30. If you have any other questions feel free to PM me and I gladly will walk you through the install. Good luck. -Steve
