cls 5 spoke amg wheel
1 Post
05 E55t, 07 R63, 04 Mini R53 (SOLD):01 s4 avant st3, 06 q7
I have seem pic on the forum, but I want to make sure if the 5 spoke CLS63 19" wheel will fit onto to our w211 E55 car with out any problem...
Well there are several versions of that wheel style and there is one offered that is made for the W211 chassis. The ones off a CLS have VERY aggressive off-sets. I do not have all my specs here with me but the SL, CLS and E all have different off-sets. The ones you would want have the 30 and 31 (or 33 i forget) ET while the CLS uses the 25 and 28 ET.
Then the tire size will have be be shrunken down depending on which off-set you go with. You may be able to go with the 285 in the rear but these off-sets likely do not allow that. So go for 245/275 on these set-ups.
The take off 255 and 285 CLS wheels that use the 25 and 28 ET for sure rub badly on a W211.
Good luck.
Good luck.
