problems with renntech elm
Old Aug 23, 2007 | 10:45 PM
Fleebee's Avatar
S211 AMG
you've checked continuity across the splice points with the module fitted and set to zero? If so, and it checks out, it really doesn't make sense if you're still throwing a code.
As for checking the voltage - It is just another way of checking that the module is being bypassed properly. If you have the same value on both splice points then you can assume that there is continuity across the module.
Old Aug 23, 2007 | 10:50 PM
rbtronnie5's Avatar
You name it i've had it or got it...
hmmm...i dont think i checked the continuity at 0...it was at 1. but i figured continuity would be continuity....the power is off when you check continuity. so as long as the circuit is checked then you are good...i checked continuity at the splice point and even beyond the splice point jic.
Old Aug 23, 2007 | 10:56 PM
Fleebee's Avatar
S211 AMG
check your PM
Old Aug 23, 2007 | 11:23 PM
rbtronnie5's Avatar
going to try again to get it to work later tonight or maybe tomorrow...i am going to set the unit to 0 bypassing any function of the actual unit and do 1 wire at a time until i find the weak link or the problem at hand...
Old Aug 24, 2007 | 02:02 AM
rbtronnie5's Avatar
Well...ate some dinner....went back at it. Went wire by wire....and now she works.....whew!!!! I FREAKING GOT IT!!! Thanks for the help everyone.
Old Aug 24, 2007 | 04:08 AM
OzE55's Avatar
2003 E55
what was the problem, then?
was it a bad connection? Not pushed all the way in?
Old Aug 24, 2007 | 09:21 AM
  #32
rbtronnie5's Avatar
no clue oz...kind of a mystery to me. i did nothing different except start it in 0 and hook up 1 loop at a time to try to pinpoint the culprit.
Old Aug 24, 2007 | 09:44 AM
  #33
OzE55's Avatar
2003 E55
Glad you got it going.
That kind of frustration drives me crazy too.
Old Aug 24, 2007 | 10:54 AM
  #34
jangy's Avatar
2015 S212
Nice, now enjoy!!
Old Aug 24, 2007 | 12:40 PM
  #35
rbtronnie5's Avatar
funny part was...frustration never ends. i was so glad it worked i wanted to see the car rolling so i had my gf drive it down the driveway and back. when she went down it she didn't go slow and the renntech carbon diffuser scraped. i was so happy the elm was working that i tried to play calm about it. luckily when i looked at it the scrape was very minimal and in a spot that you can not see on the bottom...thank goodnessssssss!!!!!
Old Aug 24, 2007 | 01:05 PM
  #36
SteveFox's Avatar
Bentley Flying Spur, CL550
Thats why you don't let your girlfriend drive ANYTHING of yours. And if you do, just prepare yourself for her to come back with some sort of damage
