EuroElites Software Tune Results!
SL55
![Arrow](https://mbworld.org/forums/images/icons/icon2.gif)
Just wanted to post here, cause this is where there is the most 55k motors.
I had been dismayed and disappointed after my car was updated at Mercedes with the dreaded 2006-0300 11 pump relay Torque load limiter Campaign. The car felt like it no longer had a supercharger! No tire spin... No Nothing, Nada. The car felt 100hp down.
There were so many companies... Large and small some on this very forums making outrageous power claims from software only ECU mods. Now I started racing motorcycles when I was 9 years old. I've been building motors since I was 11 years old... I have been a Professional Award Winning NHRA Drag Racer. I have more racing experience, and have built more race motors than ANY of these companies pushing this stuff... That's for sure.
Point one, I would like to see unbiased testimony and dyno charts showing 50+hp software only gains from these peoples products. I got news for you.. AMG Ain't that bad, and without getting more air into the car, (intake mods, Supercharger Mods, Larger throttle body, etc.) Or getting exhaust out of the car more efficiently, (headers, Less restrictive exhaust or cats, etc.) there is not that much power to be had... It has been stated that these cars are plenty rich enough... And how much can you advance the timing with out blowing the motor up?
Now Adam at EuroElites did not make outlandish claims... He did not tell me that I would get 50hp... He told me that was not possible with software alone... But this approach made me feel confident because it was inline with what I know to be true.
NOW... I'll be the first to say that I did not dyno the car before, or after... BUT, I have been tuning and test driving/riding, for over 35 years, and I can tell you this tune is AWESOME! All the power is back + a noticeable difference. The car ripping the tires off, and you just touch the gas, and the car Goes NUTS! I mean it feels like a Lot more power.
For the Value & Results, I highly recommend Adam, and the EuroElites Tune.
That's my Word.
Best,
RoydRage
That's my Word.
Best,
RoydRage
2004 E55 AMG and 2003 C320 4Matic Miss my 993 Turbo above!!
ROYDRAGE.........
What exactly did Adam do. Just an ECU reprogramming?? Have you actually documented any HP gains or is it more of a butt dyno. I have been thinking of the ECU reprogram since I put in my 80MM TB and Evo Headers but not sure if I would experience any gains........
Roland
Roland
happy2th...are you listening to this!!! bite the bullet and tell mb to f-off if you ever want your car to behave like a 55 amg should.
2003 E55 & 2014 GL550
+1,000,000!! Adam has always jumped through hoops for me and I am very thankful!!
While I am not even close to your experience and knowledge in racing, I have been to Kleemann's US headquarters in Co Springs where they did the before and after flash in front of my eyes and it was pretty cool.
My car was a touch different in that I already had a Speedtuning ECU mod on the car. We dyno'd the Speedtuning ECU flash and she pulled 491hp (They have a Dynomet that calculates drivetrain loss and tries to give you crank hp. I know I know everyone hates this, but what can you do. Info on Dynomet here)
Cory yanked my ECU and just to show off the Kleemann program, we redyno'd the car with just the Kleemann flash and she pulled 516. That's 25 hp ON TOP of an already modded ECU, plus Cory was so fast with the soldering iron, the car was still hot on the 516 run.
If you calculate that the Speedtuning ECU gave me about 15 hp, that's a Kleemann total increase of 40hp. If Speedtuning ECU was giving me 20-25 hp, that would mean Kleemann picked up pretty close to 50hp.
Just can't imagine what EuroElites or Oliver/EVOTECH's ECU tune can do. I really was impressed that Oliver took the time to sit down and "hand tune" some cars personally at Adam's place. You car must run like a MONSTER!!
I guess I'll probably have to do that. We'll see what happens when I get my car back from MB this time. Again, I'm not holding my breath.
E55
the recommendation is great, I've also heard nothing but the best from that establishment, but I'm sorry i would have expected numbers from someone with your pedigree. Drag racers rarely got by butt feeling, we go by track results, mph and dyno numbers.
Evotech 650 HP SL 55 had 2 probs while I was away...One of cylinders gets some antifreeze in it and he had his trans broken..
Olivers re-programming completely chaged the other 682HP SL55 which has been written off this summer...before I spanked him with jsut exhausts, then I installed pullies and he said he just had his ECU and TCU re-porgrammed and he started to catch ME on TOP...with 21 inch wheels...
SL55
Absolutely but you see I've been fooled by a dyno many times... I OWNED A SUPERFLOW 901! if you know what that is.. and sometimes increased dyno #'s don't equate to a lower ET.
In this case It's not worth the effort, cause as I said... The difference is NOT small, and this is not a track car... It's a street car, and this tune just makes it a BLAST to drive!
If you think about #'s you could say a tune or mod gives you 50 more HP, but what if it's at 6,000RPM? This tune makes the car more powerful down low, and in the middle revs, just what you need when a pesky C5 Z06 gets up on the side of you, and hit's it? You stab the gas, and the power is right there, right now! I enjoy the car 200% more, and if that's not worth the small investment. I don't know what would be.
When I get my pulley I will dyno the car, cause then I think the increase will be more substantcial, and what's more Adam promised to re-flash the ECU for the Pulley... So this was really a No Brainer. You can't lose with this... The car just feels rediculously fast... You just stab the pedal a little, and the car builds speed at a tremendous rate. I haven't had this much fun in a long time, and Hey... Isn't that what it's all about.
Best Always,
RoydRage
I have a question for either you or Adam.......Will this reprogrammed ECU generate more heat, higher IAT's, where a upgrade to the intercooler would be required. I am runninga 80 MM TT and EVO Shorty Headers ONLY...
Adam, perhaps you could PM and let me know what the scoop. I only have 5 weeks left before the track closes.
Roland
Roland
SL55
More Power...
Sounds like your just trying to find something negitive here... I take that same approach with everything, and trust me there is none, The car is better all around. I have no vested interest in saying so if it was not true.
I'd be here saying I got ripped off if there was a problem. But people are so quick to complain, but rarely take the time to do something positive when they are happy, So is the reason for this thread...
Nuff said.
Best Always,
RoydRage
Sounds like you just had something wrong with your car as you suspected... I can't stop my wheels from spinning and my engine is bone stock.
I'd be interested in seeing the wheel numbers too...
E55
Really does a ramp acceleration increase make the tires smoke, when tire spin was non existant before @ WOT? That was at full throttle & full power... The car is obviously making more power.
You had said,"You just stab the pedal a little, and the car builds speed at a tremendous rate." That statement along with some of the other things you've said,brings me to think they remapped the throttle curve.Whether or not this is what they did,I have no idea.I think your car had something else going on,thus the huge difference in power after Adam did the ECU flash.I dont see an ECU flash only,creating a huge noticable power difference,if the car was running fine before hand.A dyno run done the same day on the same machine is the only way to tell whats going on.
Either way,enjoy your car now that your happy with it again.
SL55
I could see where you think Im looking for the negative,but Im not.
You're absolutely correct... there was something wrong... You will notice in the first post, the first thing I said was the car was a victim of the MB update in which the car became a total dog.
But not only did EuroElites Adam/Oliver overcome the damage, they definately did make the car faster than it was before. A definate noticible difference... And for a mod of this caliper it is more than I could have hoped for. I'll be ready for the Pulley, and new tune for that Soon!
![devil](https://mbworld.org/forums/images/smilies/devil.gif)
I can't wait.
Best,
RoydRage
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
Well......here's a recent dyno of our 55K ECU set up.
https://mbworld.org/forums/c219/202602-cls55-63-tuning.html
Check the 4th post.
The way I set these cars up is to deliver the power in the heart of the power band.
Check the 4th post.
