Want to change fog lamp bulb to Xenon
Old Aug 26, 2007 | 09:42 PM
smayshusband's Avatar
2004 E55 AMG 2014 GL63 AMG
Does any one know its possible to change the fog lamps on a 04 E55 to Xenon lights ? Does the E63 have regular or Xenon fog lamps ?
Old Aug 27, 2007 | 01:20 AM
top's Avatar
top
Porsche 996TT
Yes, it looks awesome!!!
Old Aug 27, 2007 | 09:35 AM
JokerzWld's Avatar
2014 GL 350 on order
If you can figure it out please let us know! Many have tried but most setups are not seamless. There is an error message when they're installed 'bulb out'.
This republican would love to have it but so far..... Joker
Old Aug 27, 2007 | 11:00 AM
E55 RUSS's Avatar
E55K
I have it...Looks and works awesome...
Xenon need less power to charge and thats why system thinks the fog lights are faulty...
In order to have avoid the mistake...You switch the ingnition ON, switch fog lights ON, wait for 5-10secs, the system needs to adjust, then start the car and you wont have any mistakes...or switch ignition ON, turn onfog lights, switch off, then switch on and start the car without wating...Thats is the only ways...
Old Aug 27, 2007 | 11:27 AM
RoydRage's Avatar
SL55
Lightbulb HID Output Halogens!
You could save a lot of money, and eliminate the Fault light problem by going with some HID output Halogens.
I've went through 5 or 6 different ones trying to match the Xenon's, and I found the PIAA Xtreme white Plus is close to a dead match...
You should replace the Highbeams also, as both the Xenon's and the Highbeams are on at the same time when you have the brights on, and that looks like Hell... Also the city lights look terrible next to the Xenon's I've replaced those with PIAA's as well...
Also Get Phillips Stealth Bulbs for the turn signals... It will get rid of that Fried Egg look.
Now Everything on my car matches, and it looks AWESOME!!
Best,
RoydRage
