Renntech ELM - Quick Question
2006 E55, 2004 545i, 2004 FX 35
I was eyeballing my height and decided I needed to raise the rear a bit...problem was I was already on setting 7 on the Renntech ELM which is the minimum 3/8 inch drop....My question is - Can you shut off the rear (or set at stock) but retain the ability to drop the front??
It seems this cannot be done according to the manual??
2015 S212
Can't do that, but aren't there nine settings? either way, the most raised in the rear is still lower than OEM.
You can customize it all by bending the platform that the rear sensor sits on. The car will basically raise, but the ELM will bring it back down?
Mine shows 7 as the least drop at 3/8 inch....I will not be bending anything...lol....just want the rear stock and front down 3/4".....no problem, I'll live...thanks jangy.
