How to reset tpms.
Old Aug 27, 2007 | 08:20 PM
Ohio E55's Avatar
2005 E55 WAGON, 2007 Z06
Question How to reset tpms.
How do you reset the tire pressure system. I have a message on dash that says to reset after checking pressure is correct.
Old Aug 27, 2007 | 08:22 PM
turbineexpert's Avatar
w211 E55
I think you can reset through the menu buttons on your steering wheel.
Old Aug 27, 2007 | 11:50 PM
Dixit's Avatar
04 S55 AMG
Go to the tire pressure screen on the MFD where it displays the tire prssures for all the tires, then hit the R button on the speedo, it will ask to monitor the tire pressure, yes or no, select YES and after 10mins of driving it will reset and show the pressures and that alarm will be cleared.
Dixit
Old Aug 28, 2007 | 12:28 AM
Vic55's Avatar
Administrator
Dixit
I got all new sensors and using the dash computer wont do the trick. I have to go to the stealer tomorrow for a supposed sds reset.
Old Aug 28, 2007 | 12:49 AM
Dixit's Avatar
04 S55 AMG
Right that is different, Ohio E55 didnt say anything about getting new sensors. But for you new sensors have to be programmed on using the StarDiag as you mentioned.
I was mainly saying if you get an alarm cause you had a low psi tire and refilled it, you have to reset it.
Dixit
