so, will finally hit the track this monday... need advice.
I've been a drag racer for many years. Currently run at my track for points, but i'm clueless as of what to do with the E55.
So far, from what i've gathered.
Suspension is set on Comfort. or whatever the softest level is called.
The tranny is set on S?
I have a question. I'll quickly spin the tires to clean them up. Will this automatically set the tranny in 2nd gear? do i just do my burn out on C and roll to the staging lights.
I've always drag raced manual cars and the only automatic i ever owned before had a transbrake so this is all new to me.
Are you guys letting the tranny do the shifting or manually shifting the car? what rpm will the car shift at?
i was planning on removing the spare tire and setting the rear tires to 25 psi, front to 50psi.
Can't wait to get a baseline before i start modding!!!
Anything i'm missing and should add?
Back into water box,esp off,burn out.(stock tires=no burn out in water box)Stock tires,do small burnout at edge of water box or just a enough to clean the tires off.
Pull car to stage
Trans in S mode
Suspension in normal
Use button (-) on steering wheel to make sure car is in 1st gear.
At last amber roll into the throttle,dont smash it unless the track is very tacky.Roll into it smoothly but agressively.
Let tranny shift on its own.
If track isnt hooking,you'll either have to turn esp back on after burnout or peddle it off the line.Usually easier to peddle it then use the esp.
Pull car to stage
Trans in S mode
If i downshift to "1" will the tranny shift by itself?
I haven't tried this on the street... thanks. i've only had the car for a week and driven it a few times
thanks.
I run points on weekend events. I'm not in the greatest position right now, so i hope this car is consistent otherwise i won't qualify to vegas.
I'm debating whether to just bring my drag car and experiment some other day.
so.. will it shift automatically after i drop it to first?
I believe i had to manually upshift AFTER down shifting on the street, but i'm not sure.
Try comfort mode first and then sport for tomorrow instead of M mode.
Good luck, and have fun!
I really don't get into it on the street so i don't know what the deal is.
I was planning on using tomorrow as a test.
What are some good dataloggers for e55s?
thanks.
A smooth press to the floor in about a second results in the best 60' for me. (high 1.7, low 1.8 on street tires)
Suspension in normal,not sportmatic 1 or 2 mode.
Dont bring up the stall at the line,just roll into the throttle as suggested.You want to flash the convertor,but not smash the throttle and kill the convertor.
YEP, you guys know your stuff.
Roll out, soft then depress rather than smash pedal.
Car should be very consistant in non adverse air
Car is near complete point and shoot. Don't shift to 1, don't mess with suspension etc.
Just "go on the last yellow" and roll into the throttle smoothly but quickly. (bout 1/2-1 sec to get to floor instead of stomping) and that 2 ton fraulein will do the rest.
If you get bored (car tracks so smoothly I was one handing it after a couple of runs) and wanna try something fun, throw it in dyno mode and have a pass. ESP will be completely off...it's a blast. REMEMBER to turn off dyno mode when done with it. It doesn't shut off by itself. \
They took down my video of dyno mode on Putfile.com but here are the instructions .
2. Make sure digital temperature gauge shows in instrument cluster. If it doesn't, use the arrow buttons on the left side of wheel to scroll through menu until it does.
3. Turn ignition switch off and back on again to position 1 (SRS light on).
4. Quickly, while the SRS light is on, push the trip odometer reset button at the far left of the instrument gauge cluster 3 times quickly.
5. Your display should now have a voltage reading, like "UB: 12.0V" on the screen.
6. Hit the up arrow button on the left side of the wheel until you get to the display that reads "ESP Dynamometer Test".
7. Now go to the right side of the steering wheel and hit the plus (+) button once to light up the "on" button for ESP Dynamometer Test.
8. Start up the car - you're now in dyno mode. The display will read "ESP unavailable Diagnostic Test". The car will stay in dyno mode, even if you turn off the engine.
9. To turn dyno mode off, turn ignition off, then turn ignition switch to position 1 again and hit the minus (-) button on the right side of the steering wheel once until the display says "ESP Dynamometer Test Circuit 15 off." Turn off the ignition - you're back to normal and out of dyno mode.
i believe the tbw system is also one of the reasons you can't get a good launch by stalling the converter. the ecu seems to wonder why the gas and brake pedal are both being depressed at the same time and can't figure out what you really want.
the whole thing can be very frustrating compared to the good ol' days of a mechanical link between your foot and the pavement...well that is until you knock of a low 12 second run in a bone stock two ton family sedan.
I will be ready!!!
Doing weight reuction right now.
I am right behind you in several ways, dont look to the left, IM catching you
November 3rd!!
https://mbworld.org/forums/events-gatherings/207451-arizona-exotics-drag-event-speedworld-11-3-a.html
You and Bluemax gotta come out, Im going to need some help
