DIY Header Install
Old Sep 7, 2007 | 02:04 PM
Vadim @ FD's Avatar
S600TT, R350
Thank you as well. I still have the Quaife on my checklist!
You are welcome!
I will put your name on one of the Quaifes.
Old Sep 7, 2007 | 04:50 PM
mercixus's Avatar
E55
Quote:
Originally Posted by Zod View Post
Nicely done BrianS ,
Quick question,
What made you go for the evosport headers, apposed to other tuner headers?
As I am thinking of purchasing a set in the near future
Also can the car run headers with out ECU tune?
Will ECU tune give more out of the headers?
PM replied.
BrianS, thanks for nice writeup!
You are very welcome to PM me also since I have same question!!
Old Aug 29, 2009 | 10:51 PM
GRAFH's Avatar
2005 E55 AMG
Any before & after dyno graphs?
Old Sep 3, 2012 | 07:34 PM
underdogg's Avatar
2006 cls55
Do anyone have the pic to this write u I'm looking to put headers on my cls55
Old Sep 4, 2012 | 02:03 AM
Driftvs's Avatar
03 E55, HB Torana
Originally Posted by stevebez
I'd love to know if these would fit a RHD car. Are the headers symetrical? I've been told by Evosport that do not - but I aint so sure ???
Brian, Vadim?
There's a company in Sydney, Aus. Autowerks Automotive that I got my headers from.
Sonny is fantastic to deal with!!
Old Sep 4, 2012 | 10:47 AM
lowprofile's Avatar
E55
There were some pics of Sonny's headers on here a couple of years ago if you want to search. They basically looked like a set of Kleemann's.
Old Sep 4, 2012 | 10:54 AM
  #32
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
Nice beats paying 500 to 700
Old Sep 4, 2012 | 12:27 PM
  #33
johnnyblaze's Avatar
CLS63S
holy necro batman
Old May 23, 2013 | 04:46 PM
  #34
emncfi's Avatar
SLK230, E55, Trail Jeep
So kind of bumping this, but since I am doing mine, I will add my .02
manifold to down pipe:
reverse torx #13, used 2 8 inch extensions, and a flex joint
removed plugs only on O2 sensors, did not "unscrew" sensors
Driveshaft/exhaust support:
Torx T45
Front half to back half exhaust pipes:
bolt head - 13mm nut - 12mm
(I could not get my sections to seperate, but with the front downpipes on the ground, it can be slid left or right to work on the respective header/manifold
Drivers side manifold removal:
10mm nuts, top 4 are accessed above, as is the foremost bottom one, the remaining 3 lower ones access below after disconnecting steering shaft, manifold comes out from below
Exactly the same for the passengers side, top and most forward bottom nuts from above, other 3 bottom ones from below
Figured this might help someone out
Old May 23, 2013 | 11:53 PM
  #35
emncfi's Avatar
Last thing, the second from the front nut on the bottom is best accessed from a small opening basically centered behind the front right wheel. Also the exhaust section (front half) that is removed/loosened can have the passengers side pipe removed. It was easier to take that pipe off (its only held on by one clamp), connect the front half of the exhaust to the drivers side header, and once its on then connect the remaining passenger side pipe.
Old Oct 10, 2017 | 05:56 AM
  #36
jumph4x's Avatar
W210 DRFT BNZ
Thanks for this! Just replaced my factory cracked headers with... Factory intact headers, hahaha.
Old Dec 7, 2017 | 11:12 AM
  #37
Beefe55's Avatar
05 E55, 02 540i/6
+1 lol
