DIY Header Install
Old Sep 2, 2007 | 02:28 PM
BrianS's Avatar
2004 E55 AMG
DIY Header Install
I received my Evo headers Thursday and installed them yesterday so if anyone's interested in DIY, here's some pics. I did this myself but I can see where a second body would have helped dropping the exhaust.
Remove the air filters, tubes, and coil packs.
Disconnect the front half of the exhaust system and slide it out of the way.
Remove the stock manifolds and disconnect the steering shaft while your under there so the drivers side will fit.
Bolt headers in place with new gaskets and torque to spec.
Bottom view....business end.
Bolt the coil packs and other intake bits in place.
Intall exhaust and O2 sensor connections. Start it up check for any leaks or loose connections and your good to go.
Done. This ended up just being a cool pic with the light in the garage.
Old Sep 2, 2007 | 02:37 PM
Jrocket's Avatar
E55
Always nice to see somebody take the time to do a DIY write up!
Any pics of the drivers side install?
Staring at your garage floor makes me dizzy!
Old Sep 2, 2007 | 02:40 PM
Sunny55's Avatar
2005 SL55 AMG
Good job on the DIY!
Old Sep 2, 2007 | 03:06 PM
DirtyVegasMB's Avatar
'21 GLC63, '19 M5
Nice... what are the initial impressions?
Old Sep 2, 2007 | 06:07 PM
III II I I AMG's Avatar
2003 e55
how much did you pay for them? and how have them been working out for you?
Old Sep 3, 2007 | 12:44 AM
BrianS's Avatar
2004 E55 AMG
Thanks. No pics of the drivers side, sorry. Yeah, I went a little crazy on the colored flecks on the floor...
Old Sep 3, 2007 | 12:58 AM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
Brian!!
Congrats! Nicely done! Can't wait for the write up on the pulley install next week!
Old Sep 3, 2007 | 11:27 AM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
Awesome write-up.
How would you rate the difficulty of install from 1-10 ?
Thanks!
Old Sep 3, 2007 | 11:30 AM
Jrocket's Avatar
E55
Thats ok.I assume you removed the steering shaft to get the drivers side in?
Old Sep 3, 2007 | 12:36 PM
jmf003's Avatar
'03 SL55
Good job!
Old Sep 3, 2007 | 01:14 PM
BrianS's Avatar
2004 E55 AMG
Yes, I wrote that above the third pic. It was actually very easy, one 13mm hex bolt and that was it.
Old Sep 3, 2007 | 01:18 PM
BrianS's Avatar
2004 E55 AMG
Originally Posted by ChicagoX
Awesome write-up.
Thanks!
1=air filter change and 10=full engine rebuild...... I'd say about 5-6 if you're doing it alone. After I was done I wanted to give the inventor of the wobble extension an award.
Old Sep 3, 2007 | 01:28 PM
BrianS's Avatar
2004 E55 AMG
Excellent build quality and it was a true bolt-on upgrade. The car is definitely pulling harder and more willing to accelerate at higher speeds if that makes sense.
Old Sep 3, 2007 | 01:31 PM
BrianS's Avatar
2004 E55 AMG
Originally Posted by AdamG@EuroElites
Brian!!
You got it! That will be next on my DIY list, then maybe separating the supercharger cooling circuit and adding a secondary heat exchanger, and eventually installing a Quaife LSD.
Old Sep 3, 2007 | 04:16 PM
mercixus's Avatar
E55
+1
Old Sep 3, 2007 | 07:30 PM
areuv's Avatar
2005 E55 drowned/ 2011 CTS-v coupe gone/ 2012 E63 PP,LSD finally here
how about sound? is it much different from stock, noticeably louder? or is it just a nice mellow growl, this is a mod I plan on doing and am curious about the effect it had on exhaust db's, I have heard the kleeman's with cats removed and thought it was a little loud
Old Sep 4, 2007 | 10:22 AM
higginsbeach's Avatar
2004 E55 AMG and 2003 C320 4Matic Miss my 993 Turbo above!!
Hey Brian,
Those headers look familiar.........Slow down will ya, your not suppose to get ahead of me..........
Gread job. I will have news for you on my newly remapped/reprogrammed ECU. Going to the track on Wednesday so I will fill you in.......
How do you like the new tune out of the exhaust. Sweet EHHHHH.........
Take care bro.......
Roland
Old Sep 4, 2007 | 12:14 PM
BrianS's Avatar
2004 E55 AMG
It's a very mellow growl but sounds good. All cats are still in place. I should have held my db meter three feet from the exhaust before and after the install. Oh well.
Old Sep 4, 2007 | 12:34 PM
DFW01E55's Avatar
'14 ML BT
Thanks for the write up Brian, how much time did you spend on it?
Old Sep 4, 2007 | 01:25 PM
Vadim @ FD's Avatar
S600TT, R350
Brian, thank you for your business!
I have to give you kudos for DIY.
Enjoy the headers and let me know when I can be of further assistance to you.
Thanks,
Old Sep 4, 2007 | 04:53 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
I'd love to know if these would fit a RHD car. Are the headers symetrical? I've been told by Evosport that do not - but I aint so sure ???
Brian, Vadim?
Old Sep 4, 2007 | 06:22 PM
Vadim @ FD's Avatar
S600TT, R350
Sorry, not for RHD car.
Old Sep 5, 2007 | 12:16 AM
BrianS's Avatar
2004 E55 AMG
Thanks,
Thank you as well. I still have the Quaife on my checklist!
Old Sep 7, 2007 | 06:37 AM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
Nicely done BrianS ,
Quick question,
What made you go for the evosport headers, apposed to other tuner headers?
As I am thinking of purchasing a set in the near future
Also can the car run headers with out ECU tune?
Will ECU tune give more out of the headers?
Old Sep 7, 2007 | 10:07 AM
BrianS's Avatar
2004 E55 AMG
Quick question,
PM replied.
