Johnson CM30 Pump
Turned out i just wasn't pushing my car hard enough, and for long enough to notice. I also noticed it started to get worse and some times just not work at all
Anyways,,,,,,
I had my shop in West LA (LUCENT MOTORS) install this pump for me. I didn't want to go threw the hassle at the dealer, and besides i decided i should get a much better pump then the OEM since i was going threw the hassle of doing so.
The new pump works alot better. I immediately noticed the cars got more grunt, power, and more torque. Its exactly how the guy described it on the other post on here some where " It now has more *****"
I got that good deal on ebay and got the pump for <90 shipped.
Install looked pretty easy, but then again i was sitting on a chair watching one of the best shops in the country install it.
A+ mod.
Id love to race a stock e55 now, so far engine wise i only have filters and eisenmann sport exhaust, but i am pretty sure this pump will give me a huge boost.
I read a post on this site that said that most owners dont even know, dont believe it when told there car has a defective pump . CARS ARE COMMING FROM MBZ WITH THIS HUGE ISSUE and 95% of the owners dont even know it.
You can just imagine the flow on a cm90 when using 1.5 hose in and out.
If fitment is managed will it improve cooling over cm30 by alot or just a little,
Currently i have revised Mb pump, but have not done any data logging, until i get my data logger
can stock system handle such a pump?
thanks
Anyways,,,,,,
A+ mod.
I can tell you there is a different, specially with a pulley E55. My car desperately needs relief on ITA temps and even if the Johnson gives you a 10 degree drop in temps.. my car really needed it.
BTW: This mod is very simple and any mechenic can do this.
Lift the car
take off plastic covers
pump is located on the passenger side (behind the fog light) you cant miss it.
disconnect the hoses
unscrew the brackets and power connector
put the new pump with bracket
put the hoses back on
splice the cables (positive and negative) and use electrical tape
use tie wraps to secure the cables
turn on the car to test and add a bit more fluid to the reservoir
put the cover back on
and you are done.
https://mbworld.org/forums/showthrea...78#post2376178
Went to epc and is freezing on my computer and unable to get the info.
There's 2 electric pumps in the right side(passenger) of the radiator, one is smaller(lower pump) and the other on top is bigger.
Which one of the pumps will be replaced by the Jonhson pump, the bigger (top) or the smaller(bottom).
Also the stock pump has 3 hoses and the Jonhson pump has 2 conector for 2 hoses, the remaing hose should be clamped or what?
Big pump on the left and smaller pump on the right.
Jonhson Pump
thanks,
Ricardo
