Complained about the CHIRPING and........
2004 E55 AMG and 2003 C320 4Matic Miss my 993 Turbo above!!
WOW.................i guess it never hurts to ask...........I complained about the chirping and the "harshness of the engagement" and I was told after they talked to MB they would replace the supercharger clutch and other items totalling $4,000. First he said the whole supercharger and I said no that can't be. Called me later and said the SC clutch and related stuff....
I need help.......What else should they be installing besides my SC clutch as part of this job.......I know the SC clutch goes for 1,000 or so. Where is the remaining $$$$$$$
For those of you who have had this done, what else is normal as part of the fix for the chirping.
This is being done as part of my warranty. Still can't believe it........
Roland
Roland
07 BMW X5
Had mine done last month, same thing just complained about the chirping and they replaced the SC clutch. Not sure what other parts they replaced as it does not show it on the work order. I thought they would have replaced my I/C pump but no such luck, I will just take it back and have it done at later point.
'03 E55
They replaced my entire S/C. Chirp and rough engagement are gone, but it is slightly rougher than it was right after initial replacement. I was told that mine would've been $8-10k if done out of warranty.
DarkStar, I complained about the chirp/engagement numerous times to the SA with no success. Spent a little time to get to know the technician, not the SA, and suddenly I end up with a whole new S/C.
Update to Chirping Resolution........
Just got off the phone with the MB Tech. He has informed me that the entire supercharger, clutch, bearings, and pully are getting replaced. WOW. Was not expecting that.......
So this is consistent with what happened with your job.
Mine is still running great after I changed my clutch pack and that was over 1500 miles ago. No chirp and engagement is still nice and smooth. I'm starting to think that the tighter clearance spec helps with the engagement issue.
E55
Were you guys under factory warranty when they replaced the SC clutch pack?
Sounds like this should be a TSB or possible recall !!!
My factory warranty just expired ... however, i now have the aftermarket mercury warranty .. but would prefer not to make a claim with them unless it gets real bad.
I do experience a minor chirping from 1st - 2nd gear engagment .. a little bit of a quick jerk .. but, not as bad as some of you guys have reported.
E55
Mercury Platinum would cover it i am sure .. but, it seems to me this should be one of those cases where mercedes should cover it, even if out of warranty .... since they obviously are quite aware of the problem .... considering it is so freaking common.
This is not the first thread on this issue. Because of the wealth of data on this board, I went in the dealership well armed with my formal complaint. It pays to do your homework.
2005 E55, Renntech Pulley, ECU
Yep, they replaced my entire S/C unit as well, along with the pump and a bunch of other stuff. Love that factory warranty.
You guys are winning me over to the notion of buying the Mercury extended warranty... I'm super skeptical when it comes to aftermarket warranties, but it seems that I've heard enough good things from people here to suggest that it'd be a safe option. I wish MB would let me extend my factory warranty, but I'm not the original owner, no CPO for me![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Where'd you guys buy your Mercury warranty from? Do you go direct, or is it something you do with a local salesperson?
Thanks!
Skeeter
Thanks!
Skeeter
No, but I did do some dynos before the swap. If I ever get around to doing a post-dyno, I'll post before and after results for you.
Truthfully, the main diff is the lack of chirp. Can't say that it yielded any power gains. The pump had started to go, though, and that caused some serious power loss. I could get one or two good runs to sixty mph before the heat caused the blower to shut down on me big time. Same story as half of us here. What an awful feeling that is! The beast, de-fanged. Ugly.
They did the pump, clutch, entire S/C all @ once. I was a happy customer. No chirp and a return of the endless rush of torque. Fewer mods than you, just Renntech pulley and ECU, Sprintbooster on the '05.
Skeeter
Skeeter
E55
Are they aware you have an 80mm TB on there.If so,did they say anything about it,or did they give you a reason why they are replacing the entire SC?
E55
After shopping around specifically for the Mercury Platinum Warranty, they were the cheapest i found .. about $300 less then most places and about $500 less than the dealer wanted for it.
E55
Thanks!
Skeeter
Thanks!
Skeeter
Since Mercury does not use license insurance agent, they can not sell to CA people so if you go through the website, you will not be able to purchase the warranty. If you call them and if you have an out of state address then you can purchase it and use it or transfer it later on to your CA address.
